| Freeship Offset Conversion SpreadSheet? I found a xls file in this forum. But how can use it? andbody can explain clearly? for example what is F, I, 8 or 16? my offset table including only waterlines and frames values... |
I'm not sure what xls file you're using, but if it's Bryan Hansel's I believe it converts fractional Imperial measure into decimal units. If your table of offsets is in metric you won't need to convert the data. |
| my offset table is metric but how can i import it to freeship? |
| If you have a good linesplan for the boat, you might find it easier to use the "background images" feature. Otherwise, you must import the offset data in the X, Y, Z format that FREE!ship understands. You can understand Z as the vertical offset from the baseline, Y as the offset from the centerline (halfbreadths), and X as the offset from the boat's stem or stern (depending on the orientation of your original plan). Consult the FREE!ship manual and study the sample text import file provided by Martijn in the FREE!ship package. |
| do you know Rhino Offsets? it can be used for import to freeship? |
| internetturk there is a tutorial on the download section of the "old" freeship is really good and shows how ot import using xls |
| SpreadSheet for Calculation | internetturk | Software | 0 | 11-20-2006 05:54 AM |
| spreadsheet for towing calculation OF AHTS | sujith | Software | 2 | 11-17-2005 05:39 AM |
| Spreadsheet for ISO STIX | Alik | Boat Design | 4 | 05-29-2005 07:01 AM |
| speed/balance spreadsheet | hangmike | Boat Design | 0 | 10-31-2004 04:37 AM |
| Rigging sizing spreadsheet? | interlude | Boat Design | 0 | 12-21-2002 03:24 PM |
