| freeship hydrostatics I don't understand why I sometimes loose my hydrostatic features on my freeship drawing after I have been working on it for a while. Has anyone else run into this issue?
__________________ http://janetcg32.blogspot.com |
| You may have a leak in the hull . In freeships the hull must must be sealed . Check to see if there are any green points , and fix those to zero . |
| Another possibility, albeit a less likely one, is that your design exceeds the acceptable range of input variables for the hydrostatics formula.
__________________ Aluminum welding is like sex. The first few times you had at it, you probably could barely please yourself, but with practice and some guidance, you managed to impress one or two prom dates. ~PAR |
| A third possibility is that the draft of the boat is set so that the boat is either entirely submerged, or entirely in the air. See the Menu item Project|ProjectSettings|ProjectSettingsTab |
| Wrong hydrostatics and leak points with FreeShip | magwas | Software | 2 | 12-26-2009 02:48 PM |
| Extra Hydrostatics for Archimedes and FreeShip | jam007 | Software | 5 | 03-27-2008 03:04 PM |
| Freeship hydrostatics question | Timm | Software | 3 | 10-26-2007 12:20 PM |
| Freeship Hydrostatics Trim | goolawah | Software | 2 | 08-22-2006 04:30 PM |
| FreeShip Hydrostatics Question | goolawah | Software | 1 | 06-27-2006 06:04 AM |
