Old 09-23-2011, 01:14 PM
CmbtntDzgnr CmbtntDzgnr is offline
Rep: 101 Posts: 110
Freeship/Hydronship Shaft Inboard/Outboard Turn Calcs Request
Hi Victor,
Is it feasible or worthwhile to create a module for estimating/predicting propulsuion powers/forces/resistance calcs for inboard-turning shafts vs outboard turning shafts?
I read a SNAME paper from around 1992 discussing the early DD-963 problem of imbalanced gas turbines, or about them not keeping the same commanded RPMs/shaft speed when making turns, losing headway, heaving or pitching too much, and so on. A graph showed that in certain turns, an inboard shaft may experience different amounts of torque than the outboard shaft, depending on whether the shafts are inboard or outboard.
This prompted me to ask you if it it would useful feature to have an ability to estimate for such plant configurations. I imagine though that rudder placement, shaft diameter, angle, depth from surface, angle, presence or absence of keel fins or active fin stabilizers, rolling, and more would impact the results.
Thanks!
BTW, for other readers, some other things I ran across related to combatants powering/shafts/etc., are:
*** DESIGNING ALL ELECTRIC NAVAL SURFACE SHIPS
http://alamperkapalan.files.wordpres...face-ships.pdf
*** SHIP VIBRATION
http://www.eagle.org/eagleExternalPo...Pub147_ShipVib
*** PROPULSION PLANT SIMULATION FOR FAST MILITARY VESSELS
http://www.din.unina.it/HSMV%202011%.../Papers/19.pdf
Ship Propulsion Plant Transient Response Investigation using a ...
http://www.naun.org/journals/energy/19-162.pdf
Last edited by CmbtntDzgnr : 09-23-2011 at 01:23 PM. Reason: making title clearer/more meaningful
Old 09-23-2011, 01:31 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Good readings. The primer on ship vibration is really well-done.
Old 09-23-2011, 03:09 PM
Rep: 101 Posts: 110
Another one (probably seen here already, in other threads) is a Marin Report story about Holtrop & Menin
http://www.marin.nl/web/Publications...ort-2010-1.htm
It is in report 100:
"Holtrop-Mennen founders reveal the secret of method’s long-lasting success"
Drawing request robweisse Boat Design 8 02-10-2009 05:13 AM
Request Information prasanthyerneni Education 2 01-31-2008 01:49 PM
another request... tlopes Boat Design 1 10-05-2004 12:11 PM
request for sponsors jb Marketplace 2 10-22-2003 10:10 AM
request for information Open Discussion: All Things Boats & Boating 0 02-06-2003 04:42 AM
