| FreeShip developable plates incorrect size? Hi there I have created developable plates using FreeShip (for a plywood hull) - but after closer inspection the plates appear to be the incorrect size - smaller than expected. The hull is about 2.4m long, yet the longest plate shown is only 1.8m long. Any one know why this is - and what I can do to fix? Thanks very much Tim |
| I have done a a few developments from Freeship or Delftship. Built a couple. All turned out OK at least to my ability to cut by hand. Usual tolerance within 1mm. If you provided more detail it might help diagnose the problem. Rick W |
| I ran into some issues with it but it turned out to be because I didn't know what I was doing. While the model looked good, there were problem with my control points and how I had them arranged. When you turn on the grid veiw on the plates. Is the grid squares or are they stretched into none square shapes? I found out it makes a difference. |
| I should add that I only develop shapes that are developable. I also do it one plate at a time. As far as I know there is no means of nominating cut lines in Freeship. Rick W |
| Hello thuffam, I had similar problem with developable plates (less size), But I'm not sure, I have to check. |
| Thanks for your replies. I've looked at the model and it seems ok. But you are correct - it is definately something to do with a particular model - as it works fine for others. The weird thing is that the first time I open the model it works, then after closing it and reopening it, the problem occurs - but I need to reboot to make it work again. I'll try to attach the model. Thanks again Tim |
| Developable Surfaces in Rhino3D | mishnish | Software | 6 | 09-11-2008 01:05 PM |
| Developable surfaces | Boysie | Boat Design | 11 | 04-12-2008 04:22 PM |
| How do they bend metal plates and how thick are the plates? | Squidly-Diddly | Metal Boat Building | 1 | 10-23-2007 03:45 PM |
| Help need to build a developable deck | NorthCaptain | Boat Design | 0 | 06-16-2007 01:41 PM |
| Developable hull in Freeship tutorial. | SeaSpark | Software | 0 | 06-09-2006 02:54 AM |
