Old 01-08-2006, 06:22 PM
Drysideup Drysideup is offline
Freeship chines export to 2D and 3D
Hi,
New to the group and to the software (v2.3).
(*Sincerel apologies for this post ending up in Sailboats the first time).
I've successfully imported chine points and finished the design of the hull. I can create plates, but would like to export them full scale to a print shop to create patterns (wasn't planning on any CNC/laser work).
Export 2D polylines isn't available. If I try to print full scale, I can't create a custom sheet big enough. I have created a huge bitmap, but before I try to print from it, I wanted to see if there was a better way.
I also tried to export an iges to then import back into Solidworks for further detailing. Freeship says "32 surfaces exported", but when I import the iges file, SW says it is "Processing" for 20+ minutes and then I give up.
Any help would be greatly appreciated.
CS
Old 01-09-2006, 12:11 AM
CGN CGN is offline
Rep: 121 Posts: 547
"Export 2D plotlines isn't available. If I try to print full scale, I can't create a custom sheet big enough. I have created a huge bitmap, but before I try to print from it, I wanted to see if there was a better way."
when you open the screen to see the plate layout (developed) there is a button with a "compass" icon on it, click on that and it will save the plate as a doff that can be read by any cad.
if you are talking about the sections, you can go to: "project", "lines plan", find the compass icon again and click on it will save the lines plan in Dxf format.
Check your settings on importing iges files (SW) and check :
Surface/solid entities
BE-Rep mapping
Do not Knit
Free Point/Curve entities
Perform full entity check and repair errors
this may help
good luck
Old 01-09-2006, 10:04 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
Iges is having some teething problems right now, many report out of memory errors and 'locking up'.
Steve
FREE!ship 2.3 released Martijn_vE Software 14 01-18-2006 10:22 PM
3D v 2D guest12020101217 Software 10 03-24-2004 07:33 AM
