| free software for finding stabiliy??? Is there any free software for finding the stability of the ship by importing the hull to it? I use maxsurf and rhino for hull design , and I have no software for finding the stability of the designed vessel, can any one please help me??? thanks! |
| yes, but can I measure the stability of the hull designed by maxsurf or rhino? would you please tell me wheather it is possible or not????? please reply! |
| Rhinomarine will do the job but it is not free, you can download a 15 day trial version from the net, you will not be able to de-install and re-install after that. Expired is expired. If you have Virtual PC, then you can "save" the 2 virtual PC files after you have installed and "copy over the expired Rhino installation" every 15 days. Formsys hydrostatics software Hydromax is good but expensive. Mikey |
| Use iges when exporting from Maxsurf to Rhino, set zero point at forward perpendicular, set surfaces -> precision to highest and choose export as iges, 10 decimals and NURBS I would recommend turning symmetry off in Maxsurf before exporting (=you get one side), and Rhinomarine can mirror. |
| Yes, you can |
| Going to have to play around with Archimedes a bit, I think.... haven't tried it before, strikes me as useful but getting a Rhino model in seems a bit less than intuitive. Any advice on that?
| I want to know actually ,,, is it possible to measure the stability in archemedis of the hull ,which is designed by maxsurf and it is in igs format????? I use maxsurf academic to design hull and I dont have any paid software! please reply how I can do that! I want to know about archimedis or other free software for stability! |
| Download the latest service release for Rhino. use the command "AttachGHSData" (I think it's in the Bonus->Tools menu) Export the GHS data from Rhino. Open it in ArchimedesMB. Tim B.
| thank you tim b, for your nice information,,, but I have know a bit more from you! when I typed that command a winodow came " attachGHS data" , there are some option there named ,,,,," hull item,sail item, tank item ..................." but I am not understanding how to save the GHS file , I didnot found the way to do that! would you please tell me detail please?????? thanks! |
| ArchimedesMB makes life quite simple, as at the moment it only uses hull items. The easiest way to export the GHS data is to add a hull item and select half the hull (ie. port or starboard side) as the geometry. Then select "Rhino Geometry is 1/2 GHS geometry (split on CL)". Check that the other data is ok, click OK. Then use save or export to save the GHS geometry. Tim B.
| In the archimedes website you can find a basic tutorial on how to input a hull. Or read this tutorial on how to use the ghs plug in http://rhino3d.cl/GHS_UG.pdf or use Freeship instead of maxsurf and save you hull from freeship as a Archimedes or GHS |
| thank you sooo much to you all, now I can export ship GHS data to archimedes and can analyze stability and other things! |
| is there an free software for propeller design? | dongtao | Software | 11 | 05-03-2007 01:58 PM |
| need nautical software must be free ware | neptunenet | Software | 7 | 12-21-2005 12:19 PM |
| Sea Solution free software | MikeJohns | Software | 0 | 11-25-2005 01:21 AM |
| free design software? | jspeedboatb | Boat Design | 8 | 09-11-2005 11:49 PM |
| Free 3D software for propeller design??? | Unregistered | Software | 6 | 03-12-2004 03:00 AM |
