Old 10-05-2011, 01:13 PM
lumberjack_jeff lumberjack_jeff is offline
Sawdust sweeper
Rep: 99 Posts: 91
FREE!ship Plus resistance calculation question
calculations -> resistance -> calculation for re-planing and planing ships.
after extracting data from current hull, the user is prompted for which formula to use. Select "D. Savitsky".
For an outboard powered skiff, the input field for "distance between thrust line and CoG" means the distance between a horizontal line at the center of the prop and the neutral axis if the boat were attached to a rotisserie, right?
That measurement is important to predict porpoising, but the field won't accept input. It defaults to 10. Any value you input is replaced by a number 3.28* larger.
West Satsop Boatworks
Old 10-05-2011, 03:19 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
It works fine here on my PC, but the input value has to be bigger than 0.05 meters. The default value on my Freeship+ is 0.15 m.
Old 10-05-2011, 03:39 PM
Sawdust sweeper
Rep: 99 Posts: 91
maybe it's not liking my imperial units.
Old 10-05-2011, 03:48 PM
daiquiri's Avatar
Oh yes, the international settings for numerical values on a PC quite often creates problems with software.
Old 10-05-2011, 04:25 PM
Sawdust sweeper
Rep: 99 Posts: 91
I switched to metric, it works fine.
(but now my power figures are in Kw :-\ )
Old 10-05-2011, 04:52 PM
daiquiri's Avatar
Now you know how I feel when I see thermal power expressed in Btu and fiberglass cloth weight in oz.
Free!Ship 2.6+ vs Prediction resistance by Holtrop-Mennen started method Victor T Software 295 09-20-2011 04:11 PM
Free!Ship nesting how-to question -> nesting drawing gstanfield Software 5 01-02-2011 06:46 AM
Resistance calculation using HOLTROP ngyen Propulsion 2 11-18-2010 01:32 AM
Resistance calculation and propulsion calculation for tug boat sreejith Props 0 02-06-2010 03:43 AM
Free!Ship create new project question? nguyenquang Software 7 04-29-2007 09:19 AM
