Old 07-14-2004, 11:46 PM
DaveB DaveB is offline
Rep: 11 Posts: 128
fluid density in Hydromax
Hi folks,
Does anyone know how to change fluid density in hydromax? I'm trying to do an analysis in freshwater but can't seem to figure it out... I've opened the density dialog (analysis menu) but there doesn't appear to be any option to change the fluid type that the boat's in... just the type specified in tanks...
Cheers,
Dave
Old 07-15-2004, 03:48 AM
Rep: 206 Posts: 391
Dave
Go to the Density dialog, the first entry in the list, in bold type, is the density of the fluid the vessel is floating in. This is clearly mentioned in the manual and the online help for the Density dialog.
You can use the Sea Water density value in your tanks, however if you have a ship that carries water from an area of one seawater density to an area of a different seawater density (e.g. an oil tanker carrying ballast water to the Persian Gulf), the Ballast Water entry allows you to use a density different from that of the water you are floating in.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
Hydromax - moment wenc Boat Design 6 02-09-2005 12:52 PM
Hydromax and yacht stability tomcat Boat Design 3 01-24-2005 06:46 AM
Help me! (Re: Hydromax) kreg Software 6 06-11-2004 05:55 AM
