| Flamingo NXT some free new Probe and oceanwater? Does anyone have some good probes or tropical seawatermaterial i could use for my Flamingo nXt materials library? regards John |
| Formshifter here from a previous post is one way to get different water surfaces and colours. I have added the two materials for the water in the picture. The method I use to create water surfaces is as follows. I actually create two surfaces one on top of another, the top surface I create a free-form surface so I can put waves into it if needed. This surface I make a Clear glass like surface with a little amount of tint in it. To this surface I also added a bump map or in the case of the software that I use, flamingo, a procedural bump map called “rubble” I then adjust that to get the effect I want. Putting the bump on the surface makes those Wonderful little wavelets that reflect their surroundings. The second surface I make a flat plane and position below the top surface at a distance/depth at about the keel line of the boat being rendered. This surface I colour in a shade of blue to suit what I need but it can be any colour at all. The beauty I find With this method is it allows light to penetrate to a depth below the water surface so that you can get shadowing and silhouettes below the water surface, by adjusting the depth of the second surface you can adjust the amount/depth of light penetration. Hope this helps. |
| Thanks a lot for this explanation, I suppose i can get the freeform surface as wild as i want .... I will give it a try these days. Sounds pretty simple and i suppose the effects are nice. Especially the shade effect sounds appealing. Thanks again John |
| Rhino and flamingo nXt WIP | bhnautika | Software | 7 | 10-24-2011 07:47 PM |
| Rendering Teak Decks in Rhino/Flamingo. | Chris Smith | Software | 4 | 03-15-2010 04:28 AM |
| Gas pipeline probe uncovers shipwrecks in Baltic Sea | kach22i | Open Discussion: All Things Boats & Boating | 1 | 03-08-2010 09:23 PM |
| teak deck in Flamingo | Akeswins | Software | 0 | 02-07-2008 06:43 AM |
| Rhino/Flamingo rendering help ! | Vibtor | Software | 6 | 05-10-2005 02:25 PM |
