Old 05-29-2003, 01:40 PM
nemo nemo is offline
Naval Architect
Rep: 137 Posts: 132
Finite elements
Hi,
does anybody out there use finite elements programmes in naval applications? If yes, which are the most suitable for that?
Old 05-29-2003, 05:34 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Nemo,
I have to admit that I don't use any. But people I have talked to that have tried to use them for marine applications all say the same thing - "It is not a problem creating the mesh, but it is really difficult to decide on the worst-case loadings."
Steve
Old 05-29-2003, 08:21 PM
Dim Dim is offline
Rep: 110 Posts: 314
Dear Nemo,
The set of programs from SRAC:
http://www.cosmosm.com/cosmosm.htm or
I can recommend page of web-site:
http://www.bodrum-bodrum.com/vorteks...l/feacodes.htm
On my sight - one of best about software for all of us.
Dim.
Old 05-30-2003, 01:23 AM
EmilSB EmilSB is offline
Rep: 10 Posts: 85
Hi,
I try something like that with Nemecheck and with Posseidon.
I think both are good if you know how it works. But, also I think the best softwear in this category is the software which you know best.
Emil
Old 06-03-2003, 12:03 PM
dionysis dionysis is offline
Rep: 44 Posts: 256
just a thought
hi EmilSB,
While I have had limited experience with finite element software, all applications have a steep learning curve. After having an opportunity to look at Nastran, Ansys and Algor finite element packages in use, I think the best value and the easiest learning curve is Algor. Be warned, you need to learn a lot to use these packages properly; they are complex and there will be steep learning curve.
Bear in mind you wll need a way to be able to compare results so you can validate them. Get a good engineering book.
Good luck, Dionysis.
Old 06-03-2003, 12:17 PM
Dim Dim is offline
Rep: 110 Posts: 314
Will not say more precisely. In any case to work with any FEA-software, it is necessary to have specialized education.
First and most important during usage FEA-software - whether is for the person understanding that happens in PC.
Dim.
Old 06-04-2003, 05:38 AM
Rep: 10 Posts: 85
Hi,
If you want to see some stuff about finite elements see this site:
http://swath.com/maritech.htm(correction:http://www.swath.com/maritech.htm)
There you will find some pictures with result of analyse with Nastran.
Emil
Old 06-04-2003, 05:51 AM
Dim Dim is offline
Rep: 110 Posts: 314
Correct attribution
Sorry, EmilSB,
but attribution is
Dim.
Old 06-04-2003, 05:59 AM
Rep: 10 Posts: 85
Sure Dim, I never said It's my!
Old 06-04-2003, 06:29 AM
Dim Dim is offline
Rep: 110 Posts: 314
Nastran pictures.
Good pictures, EmilSB.
Dim.
Old 06-04-2003, 06:35 AM
Rep: 10 Posts: 85
Dim, a saw your gallery on this forum and your 3D Models are very good and I am woner what soft for hull form, for rendering and for detail design you use?
Old 06-04-2003, 07:21 AM
Dim Dim is offline
Rep: 110 Posts: 314
Answer
My answer - at PM, EmilSB.
Well also was lucky me with number of posts!
Dim.
Old 06-04-2003, 05:51 PM
Jeff's Avatar
Jeff Jeff is online now
Moderator
Rep: 921 Posts: 1,371
I think Dim was simply pointing out that the site doesn't work without the www because of the way they have their server set...
P.S. thanks (to both of you) for posting the images in the gallery - I really enjoy looking at them - they're great
Old 06-04-2003, 11:50 PM
Dim Dim is offline
Rep: 110 Posts: 314
Yes, Jeff and thank you for your words.
Dim.
Old 06-07-2003, 03:51 PM
Thomas Ask Thomas Ask is offline
Rep: 10 Posts: 13
I use Algor and wrote a paper on FEA analysis of hulls for the International Institute of Marine Surveyors a few months ago. I could forward you a copy of this paper if you would like.
The problem with FEA is modeling wave behavior. I used multiple surfaces on a solid model to achieve a reasonable model.
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
Skene's Elements for sale finavar Education 0 12-03-2004 09:51 PM
Regarding Skene's Elements of Yacht Design ErikG Boat Design 0 02-18-2002 06:11 PM
Finite Element Analysis of hulls Francesco Software 0 10-05-2001 12:49 PM
