Old 04-24-2006, 01:13 PM
Yacht Skipper Yacht Skipper is offline
Rep: 10 Posts: 33
Feather Transverse Flex w/ Maxsurf
Is it possible to feather the transverse Flex with maxsurf in order to start with round bilge at the bow and end up with hard chines toward the stern.
How is there any other ways to do this ?
Thanks
Old 04-24-2006, 06:45 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
YS you can get a chine at the stern by compacting a number of points into one and adjusting the weighting and stiffness.
Old 04-25-2006, 04:18 AM
Rep: 10 Posts: 33
Thanks
Thanks, I'll give it a try.
I'm new to CAD and it seems that I will never finish to learn...
Old 04-28-2006, 09:30 AM
Rep: 10 Posts: 33
Hey Nautika, I really tried several times, but end up with something impossible to fair and the chines were not sharp at all.
Any tutorials on how to do it ?
Or is there a software outthere where I could set a different transverse flex for each sections ?
Thanks
Old 04-29-2006, 01:19 AM
Rep: 547 Posts: 540
YS is this the sort of thing your after?
Feather Transverse Flex w/ Maxsurf-example.jpg
Old 04-29-2006, 04:55 AM
Rep: 547 Posts: 540
YS Just another thought, you could also bond two or more surfaces with the same longitudinal stiffness but different transverse. Then do a mix of different methods
Feather Transverse Flex w/ Maxsurf-examplexx.jpg
Old 05-02-2006, 10:25 AM
Rep: 10 Posts: 33
Thanks for your help Nautika, I really appreciate.
What I'm trying to accomplish is something like the attachment.
How would you do it ?
Old 05-02-2006, 09:34 PM
Rep: 206 Posts: 391
The key to compacting points to form chines or knuckles is to use the right number - the higher the order of the surface (i.e. the stiffer) in the transverse direction, the more points you need.
The rule is that the number of control points you need to compact is one less than the order. So an order 4 surface needs 3 control points compacted together, an order 6 surface needs 5 control points compacted together.
As you need to spread the control points out in a fair manner to fade out the chine, the less points you have the better, so order 3 or order 4 is recommended for this sort of hull shape. Note that this does not stop you using high order splines longitudinally to get the best longitudinal fairness, I would still recommend order 6 or above in that direction.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 05-03-2006, 06:50 AM
Rep: 547 Posts: 540
YS As Andrew pointed out the number of points to stiffness helps to smooth out the lines. I might suggest that a few extra points and stiffness may help the process, on smoothing the transition from flat panel chines at the stern to round bilge at the bow. The extra points help the transverse curvature lead into and out of the chine. I did a quick example of what I mean to roughly your idea.
Feather Transverse Flex w/ Maxsurf-example2.jpg
Old 05-03-2006, 10:45 AM
Rep: 10 Posts: 33
Thanks gents,
I got the idea, now I just have to practice a bit as my first attempt wasn't very succesful
Old 05-04-2006, 03:58 AM
Mikey Mikey is offline
Rep: 75 Posts: 368
Maxsurf has a limit of 25 rows and 135 columns. I think that it is possible to "trick" Maxsurf to accept more than 25 rows by transpose columns and rows. Should be enough for almost anything.
Mikey
Feather Light Design striper Boat Design 3 03-28-2006 04:06 PM
Transverse Chine Angle penningtonjeff Boat Design 5 12-25-2005 04:01 AM
Transverse moment of inertia for a mast davef Sailboats 11 02-01-2005 11:10 AM
c-flex spear Materials 8 06-04-2004 04:58 PM
c-flex spear Boatbuilding 1 09-09-2003 07:52 PM
