FEA issues with data exchange
I have been stalled by software data exchange and the likes of incompatible curves and surfaces.
Thus far into my project I am using Maxsurf to export my hull as a .dxf to Solidworks. Once opened as a 3D part in Solidworks I am unable to form a suitbale shell or bounding surface if the .dxf is my body plan in Maxsurf. I have tried this with the perspective view as well.
My goal is to create a rendered surface with some thickness. I then want to define the surface as composite laminate plys with orientation, reinforcements, balanced/unbalanced, symmetric, whatever.
I have already been through the circus of different files: IGES, 3dm, ACIS, dxf etc. Even considered the plethora of FEA software packages and tried several. However before I perform the analysis I need to define the shell or bounding surface from the wire frame that makes up the hull and deck.
My project is a 3man outrigger canoe that I have originally created using Maxsurf. I intend to build a male mold over which I will cold-mold the hull. The specs measure 34' L 18" beam. I have built a few boats but this is my first cold-mold. Someone please help
