Old 10-05-2008, 07:38 PM
lazeyjack
faring a line in Rhino
men, how can I fair a set of points or a line through these points in Rhino 4 or 2 thanks
Old 10-06-2008, 12:12 AM
raw raw is offline
Rep: 59 Posts: 133
Try the commands "Fair"
or
"Rebuild"
Old 10-06-2008, 12:46 AM
lazeyjack
thanks Brett, when i searched help , fair I found nothing, cheers, sent pm
Old 10-06-2008, 02:55 AM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
S you will find "fair" in the-- curve--curve edit tools (at the bottom)--fair. This will fair to what the programme thinks is fair but may not be what you want.You can use the curvature graph to tweak it after.
Old 10-06-2008, 03:07 AM
lazeyjack
my mate, it is nother job!!
Old 10-06-2008, 03:21 AM
Rep: 547 Posts: 540
Old 10-06-2008, 11:24 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
I find you get the best results if you first rebuild the curve to fewest points needed to describe it accurately, and then use the fair tool. After that you may have to adjust it manually and go around again until you have the curve you want. This should always be done for any curve used to build a surface.
Gary
"The hand feeds the mind."
Weston Farmer
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
On-line Charts ath OnBoard Electronics & Controls 7 06-20-2008 01:35 PM
Water line Devooo Multihulls 1 03-07-2008 04:42 AM
line-x on bottom gary1 Materials 1 05-06-2006 09:35 AM
line drawings kudu Boat Design 5 01-30-2003 12:51 AM
