| Fairing with Freeship Is there anyway to do fairing with Freeship other than try to perceive a fair curve by eye. I put the image on my flat screen lcd tv to get the view as large as possible. I was wondering if this can be trusted as a method or are there hidden problems that would only be apparent until blown up to full size developable parts? Thanks for your thoughts. |
| Yes, there is. You can import stuff from other places. you can set them as control curves (a poorly described feature in the manual I have, which is old.) Read the entire manual, and read the wiki on NURBs. An important feature of NURB surfaces is the concept of "locality". Moving a single control point only affects a limmited area and has absolutely zero affect beyond. This is different than most splining techniques. Figuring out how many control points you need to do the job and not using more than you need also aids in faring. So much for the general stuff. Fare what you got using the curvature function (bunch of pink lines). |
| Thanks philSweet. What can be imported from other places? |
| With Freeship's subdivision surfaces the locality of control points is not quite the same as with NURBS. The best tools of the trade in Freeship are zebra shading and gaussian curvature for rendering, and control curves for edges. You can change the rendering mode by right-clicking on the window and with control curves see the curvature of the edge. Add the control curve, select the pink line and check that control curves are shown. |
| I am missing a step or something. The manual on page 31 shows little purple lines perpindicular to the controlcurve but I can't seem to find how to display them. I tried to highlight the sheer and then selected "Control curves" under Visibility and the sheer turns purple but how do I get the perpindicular purple lines to display? |
| I got it! I just kept monkeying with it untiil I got the little pink lines to come on. Thanks for your help. Is there anything written on interpreting zebra shading? |
| Yes, you'll have to select the actual control curve and not the control net edge. Often this best hidden by hiding the control net. For Zebra-shading, just rotate the model and keep on eyeballing the shading as it flows. |
Also might explain why I tend to get a tiny crease down the centerline of a deck when I think I've taken pains to get rid of it. Can't force a desired slope easily with subdivisions, and control curves sometimes lead to "Runge's phenomenon" or something like it. |
| Ok, I've made it. It is done by first enabling "Visibility --> Curvature" option and then with "Calculations --> Intersections" command, by checking the station whose curvature is to be visualized. |
My version of Freeship shows curvature for intersections only in a way of which even I can be certain that it is incorrect. :/ I have just coined that feature as broken, but does it work for others? I think my version is Freeship+ 3.12 now. |
| I'm still using 2.83 because the resistance calculations work better for me there. I have the newer one too, but cannot see the resistance calculations. On a curvature you can calculate the variations between points to get them precise. You can also right click, select mode, developability check. Then move the points to where you get a smooth colour.
| I agree that there must be something wrong with the curvature plot. The curves are showing irregularities which do not result in either zebra, gaussian or shaded mode. I hope VictorT is reading this... :/ |
No luck on searching the wiki on NURBS. Can you post the link? Is this what you were referencing? http://en.wikipedia.org/wiki/Non-uni...ional_B-spline
__________________ LP ---------- God bless the open minded people of the world. LP Last edited by LP : 05-09-2011 at 08:17 AM. Reason: Deeper web based search. |
| Fairing | H.Y.C | Services & Employment | 0 | 03-18-2010 03:06 PM |
| Freeship Auto Fairing tool | coreym | Software | 2 | 09-20-2007 01:19 AM |
| anyone to help on freeship hull fairing procedure?? | yades | Software | 7 | 09-14-2006 11:03 PM |
| Fairing | bobsyachts | Boatbuilding | 6 | 07-08-2006 01:42 PM |
| Fairing | Smircio | Software | 12 | 12-10-2005 08:14 AM |
