Old 01-05-2006, 06:16 PM
Grant Nelson Grant Nelson is offline
Rep: 159 Posts: 203
Fairing a cone to hull in maxsurf
Hi All, I am trying to add a rounded bow to a hull in Maxsurf by bonding a cone. I can not find anything in the manual, or on the Formsys site that give a useful example. They discribed it in general, but then say look at some samples. The problem is that the samples use cones with an extra row and column. These are very hard to add and keep the cone shape. Also, when you add a cone it is lying on its side, and it seems when I rotate it, the column and rows are confused, because when I finally get a bond it is totally distorted. Does anyone know of a good clear example of a practical application of using a cone to create rouned bow in MaxSurf?
Old 01-06-2006, 03:11 AM
nero nero is offline
Rep: 112 Posts: 624
I do not use MaxSurf.
But if the ends of the hulls are open, then use half of the open edge and sweep it 90 degrees in 2 steps. Then mirror this surface. This will give something rounded and can be easily tweeked to fair it with the hull curves.
This works well for me in TouchCad.
Old 01-06-2006, 04:35 PM
Rep: 159 Posts: 203
Thanks Nero, while this will probably not exactly work as you describe for MaxSurf, it does give me some good ideas how to do something similar.
Old 01-07-2006, 10:12 AM
Rep: 206 Posts: 391
Grant
There is a sample design that comes with Maxsurf called Workboat, this has a good but simple bowcone. Have a look at that design, in the meantime I will put together a tutorial on bowcones and post it in a few days time.
Andrew
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Jet Drive Jet Drives 15 12-18-2006 10:51 AM
SNAME Small Craft Papers CD sorenfdk Boat Design 6 12-29-2005 04:33 PM
Hull fairing software: Rhino vs. Prosurf/FastYacht chomchan Software 2 10-18-2005 01:38 PM
