| Faceted Domes in Rhino Hi, I'm currently trying to make a Geodesic Hemisphere in Rhino 4 :s which is proving quite difficult, i'm thinking it should be possible to somehow project the triangular faces onto a sphere but am not having much success at the moment! Does anyone have any ideas how to do it or tips? This kind of thing: ![]() Thanks in advance ![]() |
| Benwhite89 the way I have done it is to make the first segments then use them to build the dome in 3d. Once you have made the necessary parts I copy, move, rotate them into position then use array to sweep them around the model. |
| Thanks bhnautica but how do you know the angles that each segment should be positioned at? Presumably you need to use formulae to calculate them? |
| Benwhite89 it not so much angles but lengths. Check out this site http://desertdomes.com/index.html it has a calculator for different size domes.There are some angles in the "conduit dome tips" Last edited by bhnautika : 05-29-2008 at 11:25 PM. Reason: more info |
| 2D Rhino to Autocad export and rhino sectioning | fede | Software | 13 | 10-18-2009 03:55 AM |
| rhino help | snow 57 | Software | 2 | 09-04-2007 05:57 PM |
| Need some help on RHINO | Barbaros | Boat Design | 6 | 08-07-2007 12:19 PM |
| Rhino + what? | Willallison | Software | 46 | 08-08-2005 04:46 AM |
| Rhino.... | Nomad | Software | 2 | 03-17-2004 03:34 PM |
