| Extra Hydrostatics for Archimedes and FreeShip As I wanted to calculate hydrostatics for a sail boat under different loadings I created this program. FreeFloat It uses .hll (Archimedes) and .obj files that can be exported form DelfShip or FreeShip. Please use it if you want and let me know if you have any comments. I have only tested it for a limited number of settings and it might have errors and most likley bugs. I recommend: Downloading the example files to see how it works. Using Java Web Start. Anders M |
| Anders, thanks and when come the multihulls? good effort and gave it a quik try but dont reconise file type? made me think of dumchikov's bio design witch was / is a rather nice free boatdesign program too with a animated displacement module, do you happen to know yours is something similar? if thats the case than i'll see to get it installed proper and try it with delftship ![]() |
| Go to my website (marinedesign.tk) and go to "free stuff" there is a GHS to hll file convertor called gf2hll Good Luck Tim B.
Could you expand on the file type problem? Quote:
The 3D view is maybe not truly animated but updated as the program is run. I made it command and file oriented to get rid of GUI since I donīt like to program those and I think it makes the program more open for mixing with spredsheets and other useful programs. |
| To use the program. Please try the example file hull.zip. Unzip the file in a directory of your choise. (Easiest is to put the files it in the same directroy as the program.) If the files are in another directory you have to set working directory using the program Menu or the command dir after you have started FreeFloat. The file commands in hull.txt can be run using the command run hull.txt to check that everything works. The file consists of the following commands: #Exempel på initiering (Example of init) echo on load hull.hll # Ställler in värden (Sets values) mass 6.5 cb 0 6 0.2 rotp cb cg 0 5.8 0 pos -0.5 0 0 #Visar 3D (Shows 3D, As the .obj file has the same name as hull.hll unly show is needed) show pause # Lite beräkning (Some calculations, Saved in test.txt) dip 6.5 0 0 out test.txt float 0 0 float 10 0 float 20 0 float 30 0 float 40 0 float 50 0 float 60 0 out Hope it helps. |
| Thanks for your help Jam007 |
| Is a Honda worth the extra $,s? | hydropathy | Outboards | 13 | 11-20-2007 09:49 PM |
| Freeship hydrostatics question | Timm | Software | 3 | 10-26-2007 12:20 PM |
| Screech, backfire and extra oil... | Chillee B | Outboards | 6 | 05-24-2007 08:38 AM |
| Freeship Hydrostatics Trim | goolawah | Software | 2 | 08-22-2006 04:30 PM |
| FreeShip Hydrostatics Question | goolawah | Software | 1 | 06-27-2006 06:04 AM |
