| External Tank definition problem in hydromax i want to describe external (non-structural) tanks inside of the hull in hydromax.But i cant do this via compartment definition in hydromax.Because my tank has taper along body plan.I have searched to hydromax help and i have learned that i cant describe those kind of tanks via compartment definition.I must model those tanks as external tank and i must model those tanks border plates in maxsurf as hull surfaces.That is OK.i did this. But the question is How can i define this tank surfaces as Buoyant volume and hoe can i calibrate this tanks in hydromax and how can i see result of the tank calibration in the loadcase window. Thanks Best regards. |
| Hi I have googled this and found nothing but jacuzzis and the ocasional sail boats. Is this it? |
If the tank is internal, but not bounded by the hull surfaces, model the tank using Maxsurf surfaces, but set their surface type in the the Surface Properties dialog to "Internal Structure", this means that they will not be included as part of the hull volume, but will be available for use as tank and compartment boundaries. Hope this helps.
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| OK Mr. Andrew i have solved my problem by your recipe.thanks for your information. Best regards |
| i need help regarding workshop .... how can i define a frame as webframe and main frame ? or how to give the frame shape L (for main frame) and T shapre ( for websframe) ? i was going to add plate at the f'castle but i cant trim the plate .. is it possible? and , how to add stringer at the inner bottom plate ? thanks student ..just learning ![]() |
| Definition of KN. | LP | Stability | 5 | 02-16-2008 04:13 PM |
| Converting water tank to Diesel tank | steve vilah | Boat Design | 23 | 06-25-2007 08:13 AM |
| external radiator for cooling system | mattoc | Powerboats | 0 | 07-01-2006 12:32 AM |
| Need help: adding external flotation pods | ghb69 | Boatbuilding | 2 | 03-28-2006 11:44 AM |
| Bait tank/ holding tank fabrication question | searaytuna | Fiberglass and Composite Boat Building | 20 | 11-17-2005 05:56 PM |
