Old 12-18-2008, 03:30 AM
kapiten kapiten is offline
Rep: 10 Posts: 5
exporting problem...
Hi There,
I'm trying to design a runabout using Freeship, and I got trouble to exporting the files to dxf and obj files.
I'm going to render it using 3Ds Max, and when I imported the file, its looks kind of awfull, lacks of mesh or polygon... is there any tricks that I can use to fix it ? ... especially with the polygon or mesh problem.
Before downloading and using Freeship, I'm a regular user of autocad and 3ds max, so this problem is starting to make me got a headache ...
Old 12-18-2008, 03:48 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
i face same problem in 3ds max, so i use flamingo/vray in rhino to render.
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 12-18-2008, 12:11 PM
CGN CGN is offline
Rep: 138 Posts: 547
Not a free solution but is fast and easy, use the demo of Moi3D, just export your file as IGES from FreeShip, then import in Moi3D and export as Obj or 3Ds
It does produces very clean meshes and very easy to tweak.
Old 12-18-2008, 06:44 PM
Rep: 10 Posts: 5
I can't afford a rhino
Rep: 10 Posts: 5
I'll give it a try ...
Old 12-18-2008, 09:45 PM
Rep: 10 Posts: 5
it works ... .... thanks for the enlightment
Old 12-18-2008, 09:57 PM
Rep: 10 Posts: 5
here are the snapshot images ...
Old 01-09-2009, 01:17 PM
antmjr antmjr is offline
hi all, this is my first post here.
Just to say I had a similar problem exporting from freeship to autocad via dxf.
I fixed it perfectly when I noticed that my freeship uses a comma ',' as decimal separator (i.e. my standard separator), while my autocad uses points '.' ; I opened then the dxf file and simply replaced commas with points.
You should control if the decimal separator in the dxf file is the same decimal separator used by your autocad.
Antonio
exporting GHS data from Rhino3d version 2.0 pavel915 Software 4 12-06-2006 04:01 PM
Exporting DXF from Multisurf to MAXSURF Akeswins Software 6 09-30-2005 05:19 AM
Exporting from autoship to modelmaker Bassoom Software 5 06-02-2005 10:51 AM
Importing and exporting between Rhino 3.0 and Autocad 2004 Coen Software 4 03-01-2005 09:27 AM
exporting Rhino to Maxsurf HELP PLEASE! fede Software 8 04-13-2004 02:05 PM
