Old 12-06-2010, 11:52 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Export IGES from Rhino
When I export IGES surfaces from Rhino, they open up in other programs without the surfaces remaining trimmed.
Is there a way of preventing this?... So that models opened in other programs appear the same as in Rhino...?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 12-07-2010, 02:39 AM
ACuttle's Avatar
ACuttle ACuttle is offline
Marine Design Engineer
Rep: 40 Posts: 85
They should remain trimmed, I've never had that problem, it's likely an export options issue.
Bare with me and I'll check.
No, I cannot get it to repeat that issue with me. What version of Rhino are you using and what type/program-version of IGES file are you exporting to?
-Drew
Old 12-07-2010, 02:47 AM
ACuttle's Avatar
Rep: 40 Posts: 85
The problem might be with your other programs:
exporting Rhino to Maxsurf HELP PLEASE!
-Drew
Old 12-07-2010, 04:16 AM
Hmmm... bummer... thanks AC....
Will
www.imaginocean.net
Old 12-07-2010, 05:33 AM
Rep: 1729 Posts: 2,462
You're not alone. I often have major issues with IGES too.
Note that Maxsurf opens native Rhino files now, as does solidworks, that saves a lot of mucking around.
Sometimes it's better to export one surface at time.
Mike Johns.
Old 12-07-2010, 05:55 AM
Yikes!!
You've seen how many surfaces I have to export!!
...and only if you have a recent version of Maxsurf...
Will
www.imaginocean.net
Old 12-07-2010, 07:12 AM
ACuttle's Avatar
Rep: 40 Posts: 85
No worries, I try to go from other programs to Rhino as my end point. Though I'd be a lot happier if programs like Maxsurf had better trimmed surface support.
It might not be much good for you application but you could try producing a tight section for your trimmed surface and then lofting the sections into a new surface that should import correctly. It won't be 100% accurate but it might work depending on what you need it for.
-Drew
Delfship export dxf surf to Rhino to Maat Hydro+ micheleoda Software 5 11-26-2010 12:03 PM
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
Export Rhino Data to Excel... jamesflett Software 5 09-06-2009 01:18 PM
Problems with Rhino->NAPA Export File Christian_S Boat Design 4 04-01-2009 10:54 AM
iges from Rhino to maxsurf workshop lazeyjack Software 3 02-28-2008 05:45 PM
