| Error when opening .GF file in Autohydro Modelmaker Hi all... this's ma first post. hope i get some replies... I modeled the hull and tanks of an AHTS vessel in modelmaker, and saved it as a .gf file. But when trying to open the same file using modelmaker, i'm getting a warning: Append gf : referenced shape does not exist! Comp: And when i press ok, im getting an error message: Error#9: Subscript out of range and Modelmaker stops responding... Could someone help me out please.... thanks in advance!!! |
| I have experienced similar errors in Modelmaker when using the "opposite" command to model tanks. You may have to use a text editor to find the referenced shape that "does not exist" in the .gf file and delete it. I have found using command files is much more reliable than the drop down menus in Modelmaker. |
| thanks Paul for your reply... i modified the names i had given to tanks- removed the commas i had used in the create command, and now ITS WORKING..!!! thanks once again |
| Multihulls in Autohydro Modelmaker? | Toplana | Software | 3 | 07-28-2011 03:29 AM |
| Who knows this error messeage of Autohydro | sys | Software | 0 | 08-31-2007 02:07 AM |
| How to solve error when import hull form from Autoship to Modelmaker | xhanasico | Software | 2 | 07-02-2007 11:10 AM |
| Autohydro file transformed to NAPA | hha | Software | 0 | 02-03-2006 03:03 AM |
| Exporting from autoship to modelmaker | Bassoom | Software | 5 | 06-02-2005 10:51 AM |
