Old 06-11-2003, 12:13 AM
Willallison's Avatar
Rep: 2283 Posts: 3,468
Engine CAD models
Most manufacturers have 2D CAD (dxf usually) drawings of their engines, but does anyone know where I'd find 3D CAD models that I can insert into my own models?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 06-11-2003, 12:27 AM
Dim Dim is offline
Rep: 110 Posts: 314
Dear Will,
After long long net searches I have come to a conclusion, that they or are made by firms-designers of the ships, or sell firms-producer of engines. If you anythings will find - give please to know about it. Basically interest 3D of the CAT (3508).
Dim.
Old 06-11-2003, 01:00 AM
Dim Dim is offline
Rep: 110 Posts: 314
3d engines models
Will,
A little finded. Recalling.
http://www.fantastic.ukart.com/53dmodels/auto/V8.zip
http://www.3dcafe.com/../models/motor5.zip
and the start point for search
http://www.3dlinks.com/objects_free.cfm
Dim.
Old 06-11-2003, 01:28 AM
Thanks Dim,
What program do you use to open the .3ds files in?
A little further thought on the subject leads me to wonder whether designers bother to insert 3D objects into a design, or if most simply insert objects into the 2D drawing views.....?
If so wouldn't this require inserting into each drawing, rather than into the model which can then be viewed at any angle / scale / section etc?
Will
www.imaginocean.net
Old 06-11-2003, 01:56 AM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
3d Studio, now 3d Studio Max? Should be able to open them in Rhino.
Old 06-11-2003, 02:26 AM
Dim Dim is offline
Rep: 110 Posts: 314
Of course, Jeff.
3ds - format opens by the Rhino ( for example ).
I try to work with complete model. But not always it is possible it to create. There is no information. As well as in this case. It is necessary for arranging engine room to use 2D drawings.
Dim.
Old 02-02-2004, 07:53 PM
Jhon
for sales software cfx autocad proengenier catia ansis
Old 02-04-2004, 11:07 AM
archnav.de's Avatar
archnav.de archnav.de is offline
Rep: 60 Posts: 208
For larger ships you can download here some gensets:
http://www.3dcontentcentral.com/3DCo...ory=&ss=diesel
New CAD Projects Available CAD Ground Press Releases 4 01-09-2010 02:10 PM
Help Wanted: CAD Talents Needed CAD Ground Services & Employment 2 03-09-2006 04:02 AM
gearboxes and potential bobber Boat Design 38 04-03-2005 12:22 PM
Diesel Engine Efficiency winap Boat Design 7 07-11-2004 04:06 AM
