| Easy-to-use CAD program for designing hulls? I have the hull-form program, but it can only do so much before you have to start building models to see what things will really look like. I have some CAD programs that I've been playing with, but I either can't figure them out AT ALL, or I can only get them to do some rather basic shapes and not complex curves like you find on a boat. Has anyone found a program like HULLS that can give you solid-object rendering? Better yet- an add-on that can use the .hul files to produce solid-object rendering? |
| Hullform is good - nice and simple and easy to use, but you need to know what you want first. Manual fairing is best instead of auto that changes the shapes a bit. There are some versions that show 3D shapes Ok. It's a bit basic, but it does the job! |
| I'm entirely satisfied with HullForm's ability to shape a hull, I'm just disenchanted with it's ability to show the hull as a solid object. All it does is basic wire modeling. |
| Help Wanted: CAD Talents Needed | CAD Ground | Services & Employment | 2 | 03-09-2006 04:02 AM |
| good cad program?? | spartin | Boat Design | 3 | 03-15-2004 09:48 AM |
| Lessons in CAD design | Willallison | Boat Design | 39 | 03-01-2004 02:52 AM |
| Wetted surface area II: Cat hulls or Monos? | Mike D | Boat Design | 1 | 09-26-2002 12:26 AM |
