| .dxf of developed plates getting scaled down?? Hi everyone! I have been searching and reading these forums for a while now and it has been very helpfull. I've designed a model boat for an rc project I am working on and I'm having some difficulty with the .dxf output. The boat that I have made is approx 4' long and all of the dimensions reflect that. When I develop the plates all of the markers and dimensions are correct however when I save them as a .dxf they get shrunk down by a factor of 12. WHY!?? ![]() any pointers would be appreciated, Also, After having played with freeship for a while now I am looking into purchasing a design program. My question is this; because I am making small model boats can I use delftship (or any other suggested program) to design a boat that can be carved out of wood by a cnc router? again, Thanks! |
| They may be coming out as inches instead of feet.Imperial units can be funny like that. |
| “My question is this; because I am making small model boats can I use delftship (or any other suggested program) to design a boat that can be carved out of wood by a cnc router?” Cutting 2D profiles from your developed panels in .dxf format is not difficult. Carving (3D surface cutting) is more difficult and may require some prep work from the shop doing the cutting.
__________________ "The hand feeds the mind." Weston Farmer |
| Thanks for the input. I've figured out how the process of designing and having a 3d plug cut by a cnc router works. I'm still having the scaling problem. It happens wether I use imperial or metric units. Does the zoom factor affect the output size? So frustrating! |
| All I can add is I would be happy to look at the file to see if I notice something.
| Could you post the .fbm file of your boat, so we could also give it a try? |
| Foil design - scaled down | dale.frahm | Boat Design | 3 | 03-29-2010 03:05 PM |
| scaled model fatigue testing | issac82 | Boat Design | 0 | 05-20-2008 09:26 AM |
| How do they bend metal plates and how thick are the plates? | Squidly-Diddly | Metal Boat Building | 1 | 10-23-2007 03:45 PM |
| Developed Plates | Tim_Hastie | Services & Employment | 0 | 09-14-2004 11:32 AM |
| developed hull plates | Tim_Hastie | Services & Employment | 0 | 06-14-2004 01:05 PM |
