| drag and resistance calculations in fastship or maxsurf hi, I have a rhino model of a hull. I was wondering if it is possible to do drag, resistance and stability calculations in either maxsurf or fastship. I have access to both the softwares but i have no experience in using them. Also i am trying to find the drag for a donut shaped hull (basically a ring or tire tube shaped hull) I wanted to know if i import such a hull type in the above mentioned software will they work. I know its a very weird shaped boat i am talking about, so i want to know if i import this shape to maxsurf or fastship will these software give me accurate results or will it screw up somewhere. Does rhinomarine work in the same way?? or will it work for this donut boat i am talking about?? |
| can somebody please help me with this??? |
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| Briefly while one the subject, can hullspeed handle stepped hulls? Browsing the website I found nothing/ |
| There is no direct method or evaluating the performance of stepped hulls within Hullspeed. There may be a way of using the Savitsky planing method to get approximate results, however i have not investigated whether this is possible. You may wish to dod a Google search for Savitsky stepped hull and see if anything turns up.
| Fastship 6.1.29 setup | romaska | Software | 0 | 08-24-2007 07:45 PM |
| FastShip vs. MaxSurf | skibber | Software | 2 | 11-16-2006 10:48 AM |
| fastship | hello | Software | 1 | 04-07-2005 12:37 PM |
| Fastship/fastyacht | RDB | Software | 4 | 10-16-2004 10:39 PM |
| fastship | Eisa Hasan | Software | 2 | 03-17-2004 09:51 AM |
