| Divide Hull with DRAPE Hi, i need to do this job, project a surface on hull, to simulate fiberglass panel. Then unfold intersection and smash to obtain a 2d shape, for cut a real piece of fabric to build a hull. Rhinoceros have this command, it's named DRAPE, but it's approsimative. |
| What are your starting with? Do you need to develop the Rhino model of the hull from lines or points? If you have surfaces then Squish is a plug-in command for flattening surfaces which are not developable and therefore need to stretch or compress. The deformation option allows selection of the type of deformation from stretch only to compress only with steps in between as well as custom type of deformation. The material option allows either rigid or floppy; presumably fabric would be floppy. It appears to only work on single surfaces. You may need to download Squish and add it. More information and download here: http://wiki.mcneel.com/labs/advancedflattening |
| Look at this pictures imagine that copper is hull, i start with X number of a sheets of fiberglass 1270 mm long X mm, project them one next others on the 3d hull model. I hold the hull of virtual sheets, cut surfaces in surplus, outside the perimeter of the hull, then unroll the surfaces generating a 2D cutting sheets! http://db.tt/ggoiEtS grazie in anticipo http://db.tt/2Pow6Ps |
| Are the hull surfaces developable? |
| It's split in 3 or 4 longitudinal Rhinoceros nurb surface. Hull is often fragmented |
| look at this picture, explain better than my words! |
| Hi DCockey, your answer has disappeared from the forum...can u post it again? ![]() ![]() |
| Dragon boat hull speed: "W" hull vs. flat hull | JosephT | Boat Design | 26 | 09-11-2010 02:44 PM |
| Hull finish on high speed hull. Polished or Matt? | Sooty | Boat Design | 2 | 02-03-2008 12:08 PM |
| what is faster a flat boat hull or a vee pad hull | riveramunizaga | Boat Design | 24 | 05-24-2005 02:18 PM |
| hull boat redesigns (hull pad project) | riveramunizaga | Boat Design | 9 | 05-12-2005 08:35 PM |
| Hull or hull & deck broke apart during 40-50 mph turn | Jeff | Powerboats | 1 | 07-09-2002 12:27 AM |
