| Developing frames for a steel build from Delftship Hi guys! I've read the manual numerous times, I've googled and googled and lurked the forums but what I am trying to accomplish is how could I get dimensions to cut out steel framing for a boat like this? Any nudge in the right direction would be much appreciated ![]() best regards, soffi |
| I'm still using FreeShip, but as I understand, the versions are similar enough for this to work. First, if you know where you wan't the frames to be, you should first edit the stations placement. When the station placement is OK, export 2D DXF-files (separate files is easier). Next you need a 2D cad-program, like BricsCad, which is a free software similar to AutoCad. Using offset you can now edit the lines to reduce the amount of hull plating, mark the slots for longitudals etc. Hope this made some sence. ![]() Lurvio
__________________ Hopefully creating something useful, since 1983. |
| solved! :) Thanks a lot! I exported to seperate dxf files and then opened in Rhino, looks good ![]() thanks! -soffi |
| I need a solution to a developing problem | ecflyer | Boatbuilding | 10 | 06-15-2010 11:41 PM |
| Hot Rolled or Colled Roll Steel Frames | MidMichigan | Metal Boat Building | 3 | 08-02-2009 06:01 PM |
| Bending wood over steel frames..? | Omeron | Sailboats | 17 | 06-29-2007 04:36 AM |
| Male or Female frames for strip build? | Nojjan | Boatbuilding | 5 | 04-22-2007 07:38 PM |
| Steel frames & ply cladding anyone | sandpiper | Boat Design | 42 | 08-16-2006 11:12 AM |
