Old 08-18-2008, 12:23 PM
mishnish mishnish is offline
Rep: 10 Posts: 3
Developable Surfaces in Rhino3D
Hi guys,
I have a bit of a problem to solve with Rhino. I have recieved the templates of an inflatable boat that my organisation has bought the design rights to develop. We have also several examples of the boat we intend to produce. Unfortunately, having religiously transcribed the templates to Autocad for CNC cutting, a lot of discreprancies started showing up. It seems like we have the templates to a MK3 version of the boat and we have the examples of and are trying to produce a MK5. The issues relate to bow height. Unfortunately there are issues with the company not supplying the right templates as instructed, and the politics of the situation among the big boys are a bit tense.
So, I have been modelling in rhino to try to get from a MK3 version to a MK5. I can develop a wireframe of the boat, loft straight sections and unroll the developable surface, but what would be REALLY useful is if I could do this in reverse, i.e. Take my template profile, make a surface out of it and then roll it to join along 1 edge to make a tube. Im sure with the power of Rhino this should be possible.....
Any thoughts?!?!
Many thanks
a stressed out naval architect!
Old 08-20-2008, 04:14 PM
aleutka29 aleutka29 is offline
Rep: 10 Posts: 10
Maybe a different software?
I don't know about Rhino, but I feel confident I could do it in MultiSurf.
Old 09-08-2008, 04:29 PM
rteng97 rteng97 is offline
Rep: 10 Posts: 16
sorry if I misunderstand you.
does it means that the template profile is a flat wire frame model?
>> make a surface
if it is flat, then you can certainly make a planar surface.
This step is too heavy. It is not simple at all. roll a surface into a tube, it sounds simple but require many actions.
Old 09-09-2008, 01:08 AM
farjoe farjoe is offline
Rep: 26 Posts: 112
how would you go about doing this in Multisurf?
Old 09-09-2008, 10:12 AM
Rep: 10 Posts: 10
u,v mapping in MultiSurf
In MultiSurf, I would take the 2D pattern and project it onto a surface which height was the same as the circumference of the tube and width was the same as the length of the tube. This could be a surface created from those dimensions or a Flattened Surface created from the tube.
I would then copy the curves from the flat surface to the tubular surface as Copy Snakes. This whole process would be done in minutes using the Insert/Copies functionality. Quite a simple procedure.
Old 09-11-2008, 12:00 AM
Rep: 26 Posts: 112
thanks i will give this a try.
Old 09-11-2008, 02:05 PM
Rep: 10 Posts: 16
"I can develop a wireframe of the boat, ..", can you explain how you can develop a wireframe that is useful for create 3d model? thanks.
Developable surfaces Boysie Boat Design 11 04-12-2008 05:22 PM
Matlab and developable surfaces mizzenman Software 1 03-19-2007 04:27 PM
I want to use rhino3d pavel915 Software 13 12-09-2006 12:04 PM
Rhino3d pavel915 Software 3 11-29-2006 05:30 AM
What is "twist" in a developable surfaces program? Ian Software 5 09-07-2004 07:14 AM
