Old 09-13-2007, 07:25 AM
Arvy Arvy is offline
Rep: 44 Posts: 114
Determine seams using maxsurf
Hi all,
Just a small question, is it possible to generate seams in maxsurf (or workshop) to develop hull plates later on? Right now I can only get workshop to expand the entire half of the hull (40 foot yacht) in 1 plate, you can imagine that this is not exactly what I want (roundbilge, huge deformations to get the compound curves etc).
Thanks for your replies (a tutorial would even be better )
Arvy
Old 09-13-2007, 09:09 AM
Rep: 206 Posts: 391
Absolutely, you can use a surface edge, waterline, buttock or diagonal as a seam, or you can specify a seam path using the stringer functions. Plate butts are usually defined by displaying and selecting sections.
Procedure is to hold down the shift key, click on the section that defines the aft butt, then the forward butt, then the longitudinal curve that defines the upper or lower seam of the plate, followed by the curve that defines the other longitudinal. You should now have 4 curves that intersect to define a quadrilateral plate. Select "Add Plate" from the Plates menu, specify some plate development parameters and you're done.
Please also refer to the relevant sections of the Workshop manual.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 09-14-2007, 08:52 AM
Rep: 44 Posts: 114
Hi Andrew,
Thanks for your reply, but what I actually meant to ask was, is it possible to generate them in such away that the developped plates can be fabricated. I already read in the workshop manual about selecting the stringers and sections etc.
So not just select the seams by means of creating extra stringers (stringers that one won't use as stringers during production, as it is not recommended to have a seam cross a stringer, or worse to coincide) that one can use to determine the seams, but have the seams actually calculated by maxsurf or workshop. The butt's can be done easily by hand (just by creating extra sections that won't be used as frames during production, but form butts with enough overlap).
Drawing the seams by hand is ofcourse possible, but I was kinda expecting from workshop that it could do it for you. But then again, workshop should keep the stringers in mind.
I am not native english, so sometimes it is hard to explain what I want to ask, sorry for that.
Grtz,
Arvy
How do you Determine Composite Thickness? solarboater Fiberglass and Composite Boat Building 4 03-31-2011 10:09 AM
How do I determine the proper pitch in FreeShip? kengrome Software 3 06-14-2007 08:58 PM
below water seams on wooden boat 64centuryhelp Materials 6 11-17-2006 01:25 AM
CPES plank seams before caulking? Dutch3 Wooden Boat Building and Restoration 2 04-23-2006 03:00 AM
How do you determine motor size lee@simmtechs.c Propulsion 6 11-22-2005 03:48 PM
