Old 10-08-2011, 01:32 AM
JordieS JordieS is offline
Rep: 26 Posts: 89
Designed frames for a boat
Hi again all,
I have designed frames for my hull and deck which are spaced 30cm apart in Rhino. Since they are just lines can I somehow print the lines out life size and then cut them into wood or will i have to get the CNC-ed or laser cut or something? How do I get those lines from Rhino to a piece wood?
See attachments for the lines for frames.
Thanks
Designed frames for a boat-deck-frame.png  Designed frames for a boat-hull-frames.png
Old 10-08-2011, 08:28 AM
Rep: 1493 Posts: 7,447
How much do you trust the program to give you fair lines?
Old 10-08-2011, 02:28 PM
Rep: 26 Posts: 89
Well I will have to see if it does, if the lines aren't fair then if its on paper I could fair them haha
Old 10-08-2011, 08:42 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
JordieS getting the lines out is pretty straightforward but you need to do some house keeping. Its is always best to keep the centre line of your model on a zero co-ordinance or better still on the zero point for all three (I like to put point mark at that location so it is easy to snap to. Put the different parts on to layers so if you need to reduce clutter you can turn off the layers you don’t need. Now to get 2d drawings from the 3d lines go to the “dimension, make 2d drawing”, then in the section/ or what ever is your front view, select the lines you want and with the drawing layout “current view” selected. You should now see in plan view / top view the lines as a 2d drawing. Another tip is to create an XYZ cross of lines, one for the centre line and one for the base line, this when selected with the lines you want will give you a grid for measurements. See file (you can take each station off separately)
Old 10-08-2011, 10:30 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
It's is more a question of the operator's skill and knowledge than the program. And that skill and knowledge requires spending time learning. Someone who is convinced something doesn't work will never learn how to make it work.
David Cockey
Old 10-08-2011, 10:32 PM
Rep: 26 Posts: 89
Don't worry everyone I've managed to print the lines out but since I printed the frames out from front view I hope rhino didn't make the frames closer to the stern smaller since they are further away than the front ones, is this an issue anyone?
Old 10-08-2011, 10:39 PM
Rep: 26 Posts: 89
It actually gave very fair lines yay!
Old 10-08-2011, 10:52 PM
Engineer
Depends on which view you printed. The basic orthogornal views which rotation doesn't work in do not have perspective and objects are the same size irregardless of the distance from the front.
David Cockey
Old 10-08-2011, 11:03 PM
Rep: 26 Posts: 89
Ok so if I printed from the front view the objects will be the right size?
Old 10-08-2011, 11:12 PM
Engineer
Yes, the curves will all be the same scale.
David Cockey
Old 10-08-2011, 11:16 PM
Rep: 26 Posts: 89
Thanks so much I can't remember the term but I think it is peace of mind, if that's what the term is then I have peace of mind now.
Thank you
Designed a boat, what next? JordieS Software 0 10-06-2011 04:17 AM
cost to have boat designed mojomfg Boat Design 45 12-15-2008 09:45 AM
So I designed my own boat... kinda tcpbob Multihulls 15 01-12-2008 06:19 AM
Repairing Sub frames in a Polyester Boat farjoe Fiberglass and Composite Boat Building 26 11-06-2007 08:01 PM
If you have designed a boat do you have to win the lotto to build it? Bertram Boatbuilding 15 08-24-2006 05:59 PM
