Old 09-19-2006, 01:54 PM
Brian Fredrik Brian Fredrik is offline
Rep: 10 Posts: 17
Design software for plywood construction
Looking for ideas on what software would be well suited to design small plywood rowing and sailing craft. Easy to learn and inexpensive are important attributes to me. Thankyou
Old 09-19-2006, 02:13 PM
Wynand N's Avatar
Wynand N Wynand N is offline
Retired Steelboatbuilder
Rep: 1625 Posts: 1,170
For software downloads, try the following links;
http://www.plyboats.com/
http://www.carlsondesign.com/
Wynand
A scatterling of Africa
Old 09-19-2006, 02:35 PM
Figgy's Avatar
Figgy Figgy is offline
Rep: 88 Posts: 315
I second the carlsondesign.com shareware. Its a good program for what your looking to do.
Imagination is more important than knowledge.
-Einstein
Old 09-19-2006, 09:56 PM
lewisboats's Avatar
lewisboats lewisboats is online now
Obsessed Member
Rep: 1263 Posts: 1,841
Carene is pretty good too, and if you pay the 35 (pounds Sterling) it will allow you to do up to 20 chines and make them lapped planks too. You can directly import it into FreeShip and play with it some more there.
Steve
Old 09-20-2006, 10:13 AM
Rep: 10 Posts: 17
Thank you all. Plyboats.com looks to have what I need for my first project.
Tortured Plywood - Design & Construction b_rodwell Boat Design 19 06-18-2006 12:16 AM
Combining Foam and Plywood construction in the Same Hull CET Boat Design 21 03-11-2006 12:25 PM
plywood vs balsa deck construction? matalag Wooden Boat Building and Restoration 33 02-27-2006 11:05 PM
Foam/Plywood boat plug construction ?s cla17 Boatbuilding 22 05-21-2005 02:44 AM
Foam / Plywood Boat Plug Construction ?s cla17 Materials 2 05-18-2003 06:45 PM
