Old 01-24-2008, 03:48 PM
NickR NickR is offline
Deltfship to Freeship
I have created a hull in Delftship 3.2, but then found Freeship 2.85 which seems to have more functionality. Unfortunately, I cannot get the hull out of Deltship and into Freeship.
Does anyone know if there is a way of translating the hull?
Old 01-24-2008, 05:25 PM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,510
I have recently done the same. What is try to click on every control point, for each station - in turn to create a text file of "curves" then read that file in Freeship - didn't work. so started again from scratch - bugger of a job......
Try Rick Willoughby? or buy the delftship commercial edition? If someone on this net has a design close to what you like, ask if you can copy it to modify for your own use?
Old 01-24-2008, 07:31 PM
Previous Member
Rep: 0 Posts: 0
Delftship Pro will export to Freeship 2.6, which could be read by 2.85. Not sure if the free version has the same feature in "Save As"
Rick W.
Old 01-25-2008, 03:52 AM
masalai
I have the "free" versions of all installed - rtfm done, all three several times particularly pp44 & equiv. No Luck..... I got one set of curves from Delft to free 2.6 but what a mess!!!!!. Re-entered from scratch. Did not like my hand entered data for curves - Linux could be adding access authorities which confuse the pure text files I guess....
Still working on it to try to sort drawings out.
Cheers
Old 01-25-2008, 07:44 AM
Previous Member
Rep: 0 Posts: 0
I am a pragmatist when it comes to computers. I use Mac and Microsoft but not Linux. I don't mind lining Bill Gate's pockets providing the stuff works.
Seems you are experiencing a lot of frustration for the sake of using something other than Microsoft. I have no idea why you have the particular problems because the software runs fine on Microsoft since it was designed for this platform.
Rick W.
Old 01-25-2008, 09:35 AM
PI Design's Avatar
PI Design PI Design is offline
Rep: 309 Posts: 604
Victor might be able to help. Try pm'ing him.
Using FreeShip pairomedicsfish Software 12 10-05-2011 01:25 PM
FreeShip lewisboats Software 6 08-03-2009 11:52 AM
iges to freeship pavel915 Software 8 08-10-2007 09:14 AM
FREEship and Terminology AstroTux Software 7 08-30-2006 09:56 AM
FreeSHIP 2.1 lewisboats Software 5 11-06-2005 05:35 AM
