Old 10-28-2011, 10:10 AM
quequen quequen is offline
Rep: 165 Posts: 113
Delftship Tutorial: How to find the sail's Center of Effort and sail's areas
Hi. I used to use AutoCAD to find sails center of effort and sails areas, but now I find Delftship / Freeship can do it faster. Is pretty simple:
1- Copy the .fbm file with a new name.
2- Open the layer box and turn off Hydrostatics, symetry, intersections, for all layers. Also, put all thikness and densities on cero.
3- Create new layers, one for each sail (main, jib1, jib2). Change working layer to one of them.
4- At the Profile view, if you have a reference image of your sails, load it and correctly scale and position the image.
5- At the Profile view, use the Tools - Add Box command to insert a new box, setting "x,y,z" coordinates of opposite corners (leave "y" coordinate at 0, so your box will have not thikness). Subdivide the sides of the box to obtain as many vertices as needed for drawing sail's border, and turn some vertices to "corner". Then drag the points of the plain box, following sail's border. Repeat for each sail.
6- Go to the layer box and put Density of the sails layers to 1, also put Thikness of the sails layers to 0.01. All sail's layers must have the same density and thikness.
7- At the layer box turn on "hydrostatics" just for the sails layers. Keep symetry off.
8- Run an "Hydrostatics Report". At layer info you have the sails areas, and at CG info you also have the position of velic centers for each sail, and at the bottom, the position of the overall Sails Center of Effort. Remember that LCG equals "x" coordinate, VCG equals "z" and TCG equals "y" coordinate (and must be 0, offcourse).
9- Finally, in "wireframe" mode, turn on the control net and use Edit-Point-Add to create points for each sail's center and for the overall sails center of effort. That's all.
Large to explain, but easy to do, trust me...
Old 10-30-2011, 03:25 AM
lewisboats's Avatar
lewisboats lewisboats is online now
Obsessed Member
Rep: 1263 Posts: 1,841
I have used something similar although less complicated. It did not however give the overall CE so thanks for the effort to figure this out.
Old 10-30-2011, 09:12 AM
Kudzu Kudzu is offline
Rep: 10 Posts: 45
This I have to try!
I have been playing with sails and this sounds great.
Old 11-01-2011, 06:40 AM
Rep: 165 Posts: 113
Lewis, you're welcome!. Will you share your own metod? may be we can make it better!
Old 11-02-2011, 03:16 PM
LP's Avatar
LP LP is offline
Rep: 385 Posts: 671
Ce
More simply, draw your sail(s) on a single layer or on independent layers. Turn "off" hydro and symmetry, as you say. In the surface properties box at the bottom of the layer properties window will be your sail area(s) and x, y, and z coordinates based on your zero datums.
LP
God bless the open minded people of the world. LP
Center of Effort vs. Center of Lateral Plane Bruce46 Sailboats 38 04-18-2011 12:35 AM
Delftship - tutorial en español quequen Software 0 01-27-2011 11:41 PM
Center of Effort Help LTDboatdesign Boat Design 8 10-29-2010 11:11 PM
Arabian 100' Trimaran, Oman Sail's new flagship multihull brian eiland Multihulls 1 12-23-2008 09:32 PM
Arabian 100' Trimaran, Oman Sail's new flagship multihull brian eiland Multihulls 1 12-17-2008 05:53 PM
