Old 08-27-2011, 03:29 PM
formsys formsys is offline
formsys
Rep: 37 Posts: 73
Export IGES from delftship to Maxsurf, see Martins comments above re some things which might affect the export.
Old 08-30-2011, 11:18 AM
azahar azahar is offline
Rep: 10 Posts: 2
thanks sir, actually i have another problem, now i'm using the demo version of delftship in demo version i can not export my file to IGES.
sir i'm really need your help, actually i'm a student and this is my final year, i had a task that need to be complied. sir can you help me, export a file from delftship to maxsurf. please sir i'm really need your help..
if you don't mind can you give me your e-mail address than i can sent you my file.
please sir....
Old 08-30-2011, 08:17 PM
formsys
Rep: 37 Posts: 73
Martin can explain your options but I think FreeShip will export for you. Im afraid we are way too busy to do file conversions for student projects, sorry.
Old 08-31-2011, 11:05 AM
CmbtntDzgnr CmbtntDzgnr is offline
Rep: 101 Posts: 110
Would it be useful or helpful to
Add more stations than needed, while in Freeship/Hydronship or Delftship PRIOR to exporting? Can MaxSurf import the 3D polylines, and then allow the user to rebuild a native surface within MS? If so, is that surface faithful to that present in FS/HS/DS? Is it possible that the polylines imported to MS not 100% faithful to the source? how tiny or negligible is the difference.
If it is possible to import the 3D polylines into MS, and if possible to manually rebuild the sideshell, I'd do that, but then also make layers and assign sideshell to various appropriated layers. As far as the sideshell goes, the layers would at a minimum represent major watertight compartments. Then, if the MS hydros/calcs can cope with that attempt on my part, I might expect that I could manually make a child model.
But, it probably is much better if possible to follow the suggestion above and use a table of offsets to be in a better position with hull faithfulness.
Old 08-31-2011, 08:27 PM
formsys
Rep: 37 Posts: 73
It depends what you are going to do with the hull shape. If you just want to do some stability, motions or resistance prediction, then perfect accuracy and fairness is not essential. In that case yes you could export sections via DXF and fit surfaces to them in Maxsurf. You could also use the trimesh option which automatically generates a hull shape over the offsets.
(See the following youtube videos:
http://youtu.be/uXAJRu6xOPI and http://youtu.be/rsppUPaGuy8)
However if you want a good quality hull for future modification and production, then you do need to move the surfaces themselves via IGES.
Old 03-09-2012, 03:05 AM
ufukozbek ufukozbek is offline
Rep: 10 Posts: 4
I am using a method as;
Delftship - export dxf 3d polylines. I use these polylines to create surface at rhino. then save as iges and insert it to maxsurf.
delftship help!!! orpheus Software 12 11-02-2009 03:26 PM
Freeship 2.83 to Delftship 3.2 Maybeoneday Software 4 07-12-2008 10:14 PM
Delftship Manie B Boat Design 3 05-06-2008 05:51 AM
Delftship Consultation Millrtme14 Boat Design 2 01-30-2008 09:40 PM
Delftship to Hullform Don Case Sailboats 7 11-20-2007 06:50 PM
