| delftship help for a noob - accurtly set deadrise angle? Can you accurtly set deadrise angle? |
| good question, so far my best solution is to use rotate stern lines in degree's, its also possible to check deadrise with 3d acrobat tools, i started with a geo triangle tho and like to hear better way's |
| i thought of a protractor in the background but there has to be a better way |
| Steve thats not bad, not bad it al, thanks, and why didnt this noob think of that ![]() |
| got to be an easier way though here ya go! |
| I would think that an Excel guru could come up with a spread sheet calculator for it. All you really need is the Y and Z coords for the bottom and chine or chine area control curve point plus the centerline coord to give a 90 deg angle then calc the angle from bottom to chine-ish. Trouble is I forget the formulas to do it. |
| Skid Fin Angle or not to Angle? | dcrummett | Powerboats | 2 | 06-11-2008 04:29 PM |
| Metal (SS) Engine cradle to set prop angle... | Roly | Inboards | 3 | 05-09-2008 03:10 PM |
| So will the real “deadrise” please stand up? [any angle will do] | Trevlyns | Boat Design | 11 | 02-02-2008 11:00 PM |
| Relationship between angle of attack of keel and heel angle | stelios | Sailboats | 9 | 05-29-2006 03:14 PM |
| What is the maximum deadrise angle? | jfblouin | Boat Design | 3 | 09-20-2004 08:36 AM |
