Old 05-12-2010, 12:01 PM
mike1 mike1 is offline
Rep: 23 Posts: 54
Delftship DXF Files
Hi, I'm having a problem with DXF files exported from delftship,
I am using a cnc machine to cut sections , and I am using software to generate the G coding,
the coding is giving a very slightly wavey line instead of a flowing curve, now this wont be a problem with the section because its less than 1mm but it makes the cnc go backward and forward and oscillate quite a bit.
Am I missing a setting or is this the kind of DXF file that delft ship produces.
It really is a bit of a hassle, at the moment I have to go through 11,000 lines of coding 4 times , to correct this
I might add that I have another design package and this does not happen when I use it.
regards
Mike
Old 05-12-2010, 01:00 PM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
Mike,
Can you post an example of the wave line and the correspnding DXF file?
The DXf file should contain a 2D polyline with straight line segments, so there should not be any wavy behaviour like you say.
Old 05-12-2010, 01:21 PM
Rep: 23 Posts: 54
Hi Martin,
Thanks
I can send you an email of the G, codeing that will show the problem ,, off list perhaps
Mike
Rhino DXF output catsketcher Software 17 01-13-2012 12:01 PM
Delftship: importing text files and or table of offsets chandler Software 33 12-27-2009 04:12 PM
Freeship files from Delftship? masalai General Computing 10 06-09-2009 09:59 AM
ProChine # and DXF files Ralph W Software 0 04-18-2009 11:47 AM
from drawing to dxf jonnyb Software 23 11-16-2007 02:35 PM
