Old 09-17-2010, 11:11 PM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
DelftShip - Chine Import
Hi all
I thought I had won lotto when I found that my free copy of Delftship had a "chine import" function to create a hull design by importing chine offsets.
I have plans for a boxy houseboat, with about 8 stations, and only three chines.
I read in a text file for the bow and transom frames only, with these settings
0 1.051 .048
0 1.114 1.12
8 0 .466
8 .766 .675
8 .871 1.387
EOF
This file has only two of the 8 stations (bow and transom) to start with.
The first line, 0 means "metres"
The next line, 0 0 0 means that the first point on the frame is located at position 0 on the X (length) axis, at point 0 on the Y (width) axis, and point 0 on the Z (height) axis.
The next line (chine) means at point 0 (length) , the point is 1.051 Y wide, and .048 Z tall
The next line (gunnel) means at point 0 (length) , the point is 1.114 Y wide, and 1.12 Z tall
This should make a boxy transom with a small chine - but if you look in the attached outcome illustration, it created something totally different.
The bow transom looks fine.
If anyone can figure out what is going wrong, I would appreciate any help.
Old 09-18-2010, 02:21 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
Looks like you've used the wrong import routine (Import surface rather than import chines).
While looking at your data I noticed both "chines" are defined at a constant x location, so in fact they are stations. Chines should be defined running from the back to the front.
Old 09-18-2010, 08:29 AM
Martijn_vE's Avatar
Rep: 401 Posts: 252
By the way, your file toolbar seems to be missing. Is that on purpose?
Old 09-18-2010, 09:38 AM
rwatson's Avatar
Thanks for the hint there Martijn.
I double checked the import option I used, and no, I did select "import Chines" originally.
Also, yes, they are stations, as I mentioned in the post, ( and yes, I did turn off the Files Toolbar)
But, I did get a hint from your helpfull reply, and re-ordered the sequence of the commands to create three chines, rather than stations.
8 0 .466
0 1.051 .048
8 .766 .675
0 1.114 1.12
8 .871 1.387
EOF
This did help, and gave me exactly what I wanted ( see attached)
Thanks a lot for the pointer - it looks like the this function is going to work for me.
a question about Delftship - start with hard chine hull? Steve32 Software 7 02-07-2010 10:50 AM
FreeShip/DelftShip - Import Offsets colinstone Software 0 04-14-2007 02:37 PM
DELFTship 3.1 IGES Import sorbit Software 2 03-27-2007 03:20 AM
Import duties Spain marchalalto Open Discussion: All Things Boats & Boating 2 10-20-2006 11:47 AM
Square chine/round chine messabout Boat Design 6 03-15-2006 09:49 PM
