Old 08-29-2002, 07:28 AM
Gades Gades is offline
Rep: 74 Posts: 125
Decks on Maxsurf
Hi there,
I was wondering how you guys design decks on Maxsurf.
Usually I duplicate the hull surface, then I flip it. Next I use the compact function to get the control points from the deck just where the hull's are. Then I delete some of the control points from the deck, because they're way too many. And flatten the duplicated hull, so that the boat looks like a normal one, not like a submarine.
This isn't the finall deck I use later, in the CAD drawings/design. But, I do need it to run Hydromax.
So, what about you guys? how do you do it?
back to composites....
Bill Gates is a very rich man today... and do you want to know why? The answer is one word: versions.
Dave Barry
Old 08-29-2002, 06:24 PM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
Possible methods:
1- Make it flat or not there at all Hydromax should close the curve.
2- For a cambered deck use a seperate surface with an edge bonded to the hull edge. Cambering can be done properly using the description given for arc surfaces in the manual with a point mid between. The Cos function is a pain to implement seperately for each control point staion but it can be done.
2- Try using a "Sheer trimming" surface and trim it. I find it best for new designs as you can change the sheer without altering the current hull shape. Could be cambered too.
Any other ideas?
Brett
Old 08-30-2002, 05:25 AM
Rep: 74 Posts: 125
Thanks BrettM,
I'm going to practice your methods and see how it goes. I might post some question later
Cheers
Dave Barry
I Want to get help in Maxsurf. zzt9876 Software 4 02-01-2005 08:48 PM
Q. Lines-planes form AutoCAD to Maxsurf ? cmcguinness Software 0 12-06-2004 05:02 PM
AC yacht modelling accurately on Maxsurf?? ac4ever70 Software 2 11-24-2003 09:48 AM
