You need to be aware that using an offset surface to get your constant frame web depth will give incorrect results when the hull skin is not parallel to the centreline of the boat. It will give the correct result for the skin thickness, and you will find the skin thickness deduction will vary around the frame based on the 1/cosine of the angle between the surface normal to the hull and the plane of the frame. However, with web frames the result will be that the web depth will vary around the frame rather than being constant, and will be different at different frames, typically being greater in frames near the ends of the boat where the hull pinches in and less in the more parallel middle part of the boat.
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| Normall you use offset surface to find the inside of the hull skin, the outside of the frames and the offset curve to make the inside of the frames. |
| Table of offsets from Rhino | maksic | Software | 5 | 10-12-2005 10:07 AM |
| software design question for Rhino Newbie | pdavidson | Software | 8 | 02-27-2005 11:04 PM |
| Transform 2D plan into 3D object | Archive | Software | 19 | 08-18-2004 09:42 PM |
