Originally Posted by APP Very nice tutorial. thanks. By the way when you have a layer of the hull, we need to subdivide it for the dxf/cnc to create the single shell panels/plates to weld. What are usually the dimensions of each panel/plate if it is developable? Is it in function of the frame span? How do you determine anyway the max size of the panels (I think are also called strakes). I hope my question is clear.
Regards
APP |
you need to divide the hull shell into layers. 1 layer for each develop-able plate. Then select "develop plates" from the menu and it will lay them all out for you.
The dimensions can be anything as the plates can be welded together from many sheets of metal to form any size/shape. The size, shape and how you break the hull into flat or single curve plates is dictated by the size and how the hull is intended to be built in practice - theres no hard and fast rules, only what is easiest in practice and achieves the shape designed is best.
