Old 11-05-2007, 06:59 PM
rapscallion rapscallion is offline
Rep: 129 Posts: 412
creating cabin tops in freeship
Is there a tutorial on creating cabin tops in freeship?
http://janetcg32.blogspot.com
Old 11-06-2007, 06:32 AM
Previous Member
Rep: 0 Posts: 0
I doubt that there is a tutorial. I extend edges or add "cyclinders" to expand the model. A cylinder with two points is a flat plate.
Exporting and importing "parts" can be useful as well. The same parts can be used in different designs.
There are usually more than one way to do something. As far as I can see there is nothing it cannot do with a bit of effort and typically it is simple once you find the way.
I have now got some proficiency with FreeShip and it comes from just using it. Certainly frustrating at first. My biggest step was learning to use the mouse buttons to zoom in or zoom out and move the image around the screen. This allows you to get close to detail. If you have a lot of detail then make different layers so you can hide parts.
Hope this helps. If you want something specific then post your model file and ask the forum members to add what you want. You can then ask how it was done. I have found others problems useful in working out better ways.
Rick W.
Old 11-06-2007, 03:51 PM
juiceclark juiceclark is offline
Previous Member
Rep: 71 Posts: 373
I give up
With the measurements in hand I was able to make a decent looking hull bottom on Delftship. But it's beyond this dummy. It'll take more time to draw it correctly (with topside detail) in the program than to build the darn thing by hand.
I think I'll have to leave 3D drawing to people who understand it and I'll stick to dealing with the ichy resin stuff.
TC
Old 11-06-2007, 04:06 PM
Previous Member
Rep: 0 Posts: 0
TC
I said it can be frustrating.
Like all things that are worthwhile doing it takes practice and you get better with practice. Keep in the back of your mind that it is possible and should be easy and you just have to work out the best way. Sometimes you just have to have a break and rethink what you are doing.
Rick W.
Old 11-06-2007, 07:12 PM
lazeyjack
TC
I tried for literally 100,s of hours, got not far, except ion freeship, I then met a member who tutored me online , we voiced in msn, we had rhino open, but for him I would still be looking at the pages
So, find a tame tutor
Old 11-07-2007, 01:12 PM
Previous Member
Rep: 71 Posts: 373
Great idea Jack and thanks for the inspiring words Rick. I think around February I'll be able to talk someone up north into flying down to help on Rhino and go to the beach in the meantime!
Tony
Creating a strong enough transom TP-Mike Boat Design 1 02-11-2006 01:02 PM
T-Tops ironpirate Boat Design 3 01-05-2006 09:50 AM
18-24' Cabin / Half cabin moulds Louis Boat Molds 0 07-27-2005 03:48 AM
Granite Tops In Boats mark lauzon Boat Design 5 02-27-2005 02:04 PM
T Tops and Towers TTopper Boat Design 0 11-07-2004 11:02 AM
