Old 10-02-2011, 04:32 PM
Eguccio Eguccio is offline
Rep: 10 Posts: 2
Create Trimaran- Maxsurf
Hello
On maxsurf i'm trying to create a trimaran. I'm only getting basic desing of trimaran so i want to join three basic yatch hulls.
Firstly i arranged other hull centre line then try to move the simple hull. But when i moved it, it parted into two hulls. I really don't understand why it parted.
After that How can i join three hulls,
Thanks a lot.
Old 10-02-2011, 07:10 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
Eguccio you need to create the other surface of your outer hull. The quickest way would be the surfaces, “flip surfaces” command, pick the hull surface then tick the duplicate box, then select the transverse box and enter the position of the hulls centreline control points.
Old 10-03-2011, 11:38 AM
Rep: 10 Posts: 2
Hello
Thank you i have done 3 hulls with your instructions and i need one more help in join issue. When i use "join surface" command, it is so useless. So i think i should make surface between two hull but How ?
Or can you give advice on join three hulls with diffrent methods
Create Trimaran- Maxsurf-three-hulls.png  Create Trimaran- Maxsurf-joined.png
Old 10-03-2011, 06:39 PM
Rep: 547 Posts: 540
Eguccio you are right about having to create a surface between the hulls as the “bond edge/join surface” will make one surface edge conform to the other as in your second picture. If you create a horizontal surface with the same number of control points and with the same longitudinal stiffness, then bond the edges to each of the hulls, you can add transverse points to get curvature. See example
create shell profiles in rhino naserrishehri Software 0 01-27-2011 01:38 PM
Cannot create offsets in Maxsurf Academic... mystrwizard Software 1 11-29-2009 03:47 PM
Create mold from existing boat nachoman Fiberglass and Composite Boat Building 4 01-26-2009 09:45 AM
How to Create 3D Hull from Flat Panels? DougChapman Software 4 09-20-2005 01:03 PM
Use Rhino to create surface between stations? ivansalasj Software 9 01-18-2005 04:08 AM
