Old 04-19-2011, 10:17 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
Copy/Paste in Rhino
In rhino when I want to copy an object from one file to another by the command copy, then then in the destination file the copied objects goes to a place which is not controlled. I want to paste to a definite place with respect to a reference point. As I can do this work in AutoCad by " copy with baste point " command which I find by right clicking in the window, I am searching for similar kind of command in Rhino.
Can I copy directly from Autocand to Rhino by any command( without exporting the object as a dwg file)?
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 04-19-2011, 11:45 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Not "copy" and "paste" but you can make the object a block using the "Block" command, and then insert it where desired using the "Insert" command.
When you paste an object it appears to go to the same location it had in the model it was copied from.
Old 04-19-2011, 12:49 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
"Export With Origin"
Old 04-19-2011, 06:36 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
The copy and paste function works well if you open rhino twice (this is where twin monitors come in handy). You then have a destination rhino file in one rhino and a copying file in the other, which you can change to get the file/object that you need. I first select the object I want to add to the other file and make a “transform” copy which I add a point object to (as a reference point for the object) and then move both to either 0,0,0 and to a known point. Then do a copy/paste into the destination rhino file. No you can’t copy/paste from different programmes.
Anyone have copy of 1964/1976 Savitsky papers? dennisolcott Boat Design 31 10-27-2010 12:37 PM
20' HST Hydrostream Tunnel-V Molds (copy) johnboat75 Boat Molds 0 07-22-2010 12:35 PM
Admiralty Formula/Henschke diagram - Searching a copy Vincent G Boat Design 3 04-04-2010 02:56 PM
MOLDS FOR 20' Tunnel-V HST Hydrostream (copy) johnboat75 Marketplace 0 02-19-2009 03:02 PM
Where do you draw the line... Steal/Copy/Borrow/Immitate ideas & concepts ErikG Boat Design 21 02-25-2005 03:16 PM
