Old 10-16-2003, 10:31 PM
Willallison's Avatar
Rep: 2283 Posts: 3,468
coordinate directions in Rhino
I'm sure there's a global comand to fix this, but I haven't found it yet....
I'm used to having, for example x = 0 at the right, increasing as you move to the left.
Short of rotating each of the view panes each time I start a new model, is there a way of doing this globally?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 10-17-2003, 08:40 AM
cgorton cgorton is offline
Rep: 10 Posts: 50
X Coordinates
That seems opposite of what most CAD programs do, but kind of makes sense if you're used to seeing boat profiles with the bow to your right.
I don't know if there's a global command to shift that, but you could rotate your views then save the blank document as your own template file. When you start from scratch using the template it will be set up the way you want it.
Old 10-17-2003, 01:04 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
This still confuses me, some software uses UCS that you can define. Rhino has CPlane; you can find this under View. I have not found out how to change the defaults. One other thing to remember is if you export to other software it will be in World.
Gary
Old 10-17-2003, 06:23 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Will,
Just get used to the X dimension always being negative. It takes less time than trying to change it.....
;-P
Old 10-17-2003, 06:53 PM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
I usually have my origin at the transom (UCS anyway) with positive forward. It doesn't matter how you label your axis anyway. 0 can still be at the bow. The UCS does't get onto your output anyway. A lot of drawings I don't even bother to set the origin as I work relative to baselines anyway.
Old 10-19-2003, 06:32 PM
hmm.... fair enough. Though I'm surprised that nobody's been bothered by it before - given that the convention is to have the bow facing right. It's kind of confusing to me, as all the marine software that I've tried before has X increasing to the left. But then I guess I have to remen\mber that Rhino isn't just a marine modelling tool....
As always, thanks for the input - I'd be completely lost without you guys....
Will
www.imaginocean.net
Old 10-26-2003, 06:57 AM
Polarity Polarity is offline
Rep: 148 Posts: 480
Hi Will
Right click on (for example) "Front">set CPlane>x axis. click on 0,0 and draw left. Repeat as required for other views.. If you then go to "named views">save and save it as Front it should default...
Or you can save it as part of your template (probably safer!)
That do it for you?
Paul
Old 10-26-2003, 05:27 PM
Aha!! Thanks Paul!
I had a read through the manual last night (when all else fails.... ) and thought there was a procedure something like that to 'fix' things. True to form - you guys are MUCH easier to decipher than the manual.....
Will
www.imaginocean.net
Old 10-29-2003, 03:07 PM
ClarkT ClarkT is offline
Rep: 10 Posts: 96
Will, I think you can get what you want simply by viewing the Left instead of Right <default> view
Old 10-29-2003, 05:08 PM
Hmm - without checking, I do believe you may be right! Can't believe I didn't think of trying that! No Matter - one way or another, I'll be able to get what I'm after - thanks to all.....
Will
www.imaginocean.net
Old 11-12-2003, 08:50 PM
FYI - I tried the methods you guys have suggested and unfortunately none of them work! Rotating the construction plane has no effect on the world coordinate system, so even though it appears to give the disired results, when you add a point at say 1,0,0 it will still be to the 'right' of one added at 0,0,0.
Looking from the back has a similar effect.
So next stop was Rhino tech support - and here the news is no better....
Hi Will:
Unfortunately no. From the ground up, V3 Rhino is a standard Cartesian "right-handed" Z-up application. This has been requested before. I know it is on the Rhino wish-list but I don't know if it will be possible to get it into V4 or not.
So - there you go - can't be done.
But wait - I do seem to recall something in the manual about entering coordinates with a prefix, so they relate to the construction plane, rather than world coordinates. If that's so, then maybe combined with the rotated construction plane......
Will
www.imaginocean.net
Old 11-13-2003, 11:23 AM
Senior Dreamer
I share your frustration when entering coordinates manually. If you forget the – and hit enter, you wonder where the point went. I suggest that all those that find this a problem, drop a line to McNeal, and ask that they add to the wish list the option of changing the settings for the world coordinates. I have found this a very useful option in the CAM software I use.
An interesting note is that in H I Chapelle’s, Yacht Designing and Planning, the drawings have hulls with the stem to the right and the left. It seemed not to matter which way he drew them.
Gary
Old 11-13-2003, 04:47 PM
SailDesign's Avatar
Gary and Will - you guys need to get lives ;-P <just kidding!!!>
If you just "go along" with Rhino, you'll get used to it in no time. Or just imagine it's Autocad and use the "@distance<angle" format all the time.
Yeah, I know it's a pain, but then so was drawing in 2D, and we were all used to that.
Steve
Old 11-13-2003, 06:17 PM
Huh! I still do most of my drawing with a pencil !
The tech support guy said that he'd 'bring it up again at the next meeting......
Will
www.imaginocean.net
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 03:55 AM
Rhino <-> AutoCAD conversation Tobias Software 3 08-14-2004 12:34 PM
Rhino Newbie Act Too... jprev Software 17 02-19-2004 01:30 PM
Fairing in Rhino shu Software 13 01-06-2004 10:38 AM
Rhino blewett_john Software 29 01-18-2003 06:05 AM
