Old 09-19-2008, 08:30 AM
jprevj jprevj is offline
Rep: 10 Posts: 5
Control Point Problem in Freeship 2.6
I've been using Freeship for years and have never had any kind of problem with it. Now I have a control point that is in the middle of a dingy design that has somehow changed itself to a corner point. I have tried clicking the corner point dialog box and it will remove the check mark but it just won't change the corner. I have tried shutting down and restarting both Freeship and my computer. I have tried inserting another point and deleting the problem point but when I delete the problem point it takes away 3/4 of my bottom.
I could, I guess just do the design over, unless someone has some suggestions on how to fix the point.
Thanks,
JP
Old 09-19-2008, 09:27 AM
lewisboats's Avatar
lewisboats lewisboats is online now
Obsessed Member
Rep: 1263 Posts: 1,841
The picture isn't big enough to see exactly what is going on. Is the point in the middle of space? Suggestion 1: Have you tried not deleting it but collapsing it? Suggestion 2: turn on faces and get your bottom panels onto one layer, then try deleting the point. if that doesn't work, try creating a new layer and assigning that point only to the layer then delete it. If worse comes to worse...copy all the info for each point that makes the centerline, delete the layer and extrude a new bottom, then adjust your points to match what you had. Make a backup copy before messing with things in any case.
Steve
Old 09-19-2008, 09:42 AM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 252
First of all, if three crease edges meet in an point then that point is always a corner point, can't change that.
To remove a point (and maintaining the geometry) use collapse rather than delete. The collapse option only works if the point connect exactly two edges.
Old 09-19-2008, 11:14 AM
Rep: 10 Posts: 5
Thanks. Collapse worked!
JP
Freeship offsets excel import problem h.siereveld Software 3 05-30-2008 08:13 AM
Point me in the right direction Kaptin-Jer Diesel Engines 11 03-03-2008 08:53 PM
Intriguing "problem" with FREEship AstroTux Software 9 07-23-2006 03:16 PM
Moving multiple control points in FreeShip SeaSpark Software 4 06-15-2006 06:02 AM
Can someone please point me in the right direction? eitanwaks Open Discussion: All Things Boats & Boating 7 05-17-2006 08:07 AM
