| Cobalt Does anyone of you know Ashlar Vellum Cobalt? It's a Parametric Solid, but also freeform modeller. I've been told it would be ideal for naval designer. Compared to other solid modellers, such as SolidWorks, it allows a better managing of freeform surfaces, even if there's SurfaceWorks, an add-in for solidworks, but that's not a definitive solution. http://www.ashlar.com |
| nope.. but then I did not even underdstand the description: "powerfully integrates advanced parametric free-form Wireframe, organic Class-A NURBS Surfacing, and advanced ACIS feature-based Solid modeling. " WHAT??? Going to check for demo download to see if the product is as complex as the PR!!...................... Got it! A mere 84 mb. Start download . go to bed! g'night! Paul |
| A solid modeller is slightly different from what you're used to think about CAD, you start from a sketch, the you use dimensions to get the exact geometry you want, then you can create solids from the sketch. Its power is in the flexibility: you change a dimension, and all the model changes with respect of the relations you gave. All the "operations" you make on the solids are called "features" and they're visible on a feature manager tree. NURBS surfaces are the ones you can Handle even in Rhino. Stefano |
| Thanks Stefano! I'll give it a go later. I got the NURBs surface bit but even reading the site was not sure what the rest was about. Did you download the demo? |
| Yes I downloaded the demo but still didn't have the time to try it.. I know it's not as intuitive as Rhino.. stefano |
| one bang ployester resin layout ??? | newo eloc | Fiberglass and Composite Boat Building | 8 | 07-20-2005 01:09 AM |
| Cobalt anyone?! | Rupes | Software | 1 | 12-04-2004 05:47 PM |
