| CFD sail profile help Hello everyone, I'm new to this forum so please move this thread if it is in the wrong spot. For my final years dissertation i chose to do some computational fluid modelling of the aerodynamics of sails. I'm blowing non-tubulent wind through laser sails at different points of sailing. I am a laser sailor, race regularly but not excessively and finish usually in the 2/3 of the fleet at club racing, so I know how things work reasonably well.
For each point I think I have the correct sail shape in plan view. Here's my attempt: Close Hauled ![]() Maximum camber (0-9):3 Max camber pos. (0-9): 2 Thickness (0-99): 0 Point size: 4 Beam Reach ![]() Broad Reach ![]() Am I correct? Using the link, what do you think the three points should be set at? Use the sliders to change the aerofoil's shape - make thickness zero (negligable) and ignore the sliders below "# Points". |
| If you just sail a Laser, why don't you put a trimming line on the, let's say, 1/3 of the sail and take a picture of it, from bottom-up? Then you can easily compare the curve with the shape you are selecting in the software ... this is usually done in larger yachts. You can see an exmple with a Finn with ShapePlot, or you can try AccuMeasure. To cite a few examples. Good look!
__________________ ------------------------------------ Humberto Martínez Barberá jSDN Yacht Design Software |
| 2-d CFD analysis of sail-mast in FLUENT | Panos_na | Software | 0 | 11-14-2009 10:17 AM |
| Buckling of profile | pulsar | Sailboats | 11 | 09-18-2007 12:14 AM |
| Sail CFD - Help interperate my results | m_liddell | Sailboats | 18 | 05-07-2005 10:42 AM |
| hull profile. | bevan | Boat Design | 1 | 02-03-2004 06:51 PM |
| Profile | Nomad | Open Discussion: All Things Boats & Boating | 1 | 02-05-2003 02:51 AM |
