Old 07-26-2010, 12:32 AM
honer827 honer827 is offline
Rep: 10 Posts: 4
Center of gravity in Rhino?
How can I find center of gravity? Is there any command?
Old 07-26-2010, 03:51 AM
Rep: 10 Posts: 4
nobody knows that?
Old 07-26-2010, 04:59 AM
LyndonJ LyndonJ is offline
Rep: 233 Posts: 302
Click on Analyze header Then Mass properties.
Working with solids its volume centroid.
For surfaces it's area centroid You can select multiple surfaces or solids and get the total collective centroid without doing moments or you can ge them individually and do the moments ...whatever.
Hope that sort you out
Old 07-26-2010, 05:01 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
if you want to get the CG of an individual surface or solid then you can use this command:
analyze>mass properties>area centroid (for a surface)
or
analyze>mass properties>volume centroid (for a solid)
If you want to get the centroid of a system of many surfaces and solids , then i think you need rhinomarine or Orca3d. In rhinomarine and orca there are options for assigning density to a material and one can get the CG of the whole system.
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 07-26-2010, 05:08 AM
Rep: 10 Posts: 4
Thanks. This command solved my problem.
Calculating Center of Gravity, multipliers? mcm Stability 8 05-06-2010 04:22 PM
centre of gravity hbr Boat Design 4 08-14-2007 02:56 PM
center of gravity estimation hbr Stability 2 08-14-2007 10:32 AM
High Speed Boats. Center of Gravity mvd535 Boat Design 21 07-09-2007 11:56 PM
Center of Gravity Gene H Boat Design 2 03-01-2007 07:58 PM
