| Carene, exporting panels I have begun to get the hang of using CARENE software, however I was wondering what is the best/easiest way to export the layout for the individual panels. Searching the forums has yielded some suggestions, most of which I was not familiar w/. Just wondering what you do? |
| Carene doesn't have many adherents...so you may have trouble finding much info on it. I have used it for years so I am pretty familiar with it. What you have to do is you have to print the offsets for the panels. This takes quite a bit of paper but if you have a program that makes pdfs via a virtual printer you can use it to get your offsets without going through half a ream of paper. You can also save it in various forms and import into a CAD then go from there. The offsets from Carene are in metric only but I have successfully used the program and gotten good offsets by just thinking of the numbers as feet. I do the design like it is in feet and read the offsets like they are also. Be prepared to use a calculator because the stations are not at even intervals but rather the boat is divided into something like 80 slices (regardless of the length of boat) and numbers are given for each slice. Your numbers will come out like this 12.8961 which must be converted to feet and inches or leave as is if you are using metric. You will VERY rarely see an even number. Steve |
| File: Print: either development or all offsets. All offsets gives you the offsets for the whole hull along with the panels and some other info. You won't get pictures with stations etc...you will get a plain outline of the panel and sheets of numbers which are the offsets for the points that you plot and spring a batten to to draw the outline on your stock or pattern material. |
| Damn, I hadn't used the program for a while and just fired up that computer. I was using the CARLSON Design software. Sorry for the confusion. One of those days....! |
| Computer hydrostatics reliable? carene / delftship | stonedpirate | Software | 12 | 04-10-2010 10:45 PM |
| help with Carene to Delftship printing | pistnbroke | Software | 5 | 03-31-2010 01:27 AM |
| exporting problem... | kapiten | Software | 7 | 01-09-2009 01:17 PM |
| Exporting from autoship to modelmaker | Bassoom | Software | 5 | 06-02-2005 10:51 AM |
| exporting Rhino to Maxsurf HELP PLEASE! | fede | Software | 8 | 04-13-2004 02:05 PM |
