Old 01-08-2008, 04:09 AM
ct marine nz ct marine nz is offline
Rep: 10 Posts: 28
carbon pattern in rhino
can anyone point me in the right direction for a decent carbon pattern I can use for rendering in Rhino the one flamingo comes with is terrible
Any help appreciated
Old 01-08-2008, 09:26 AM
Rep: 206 Posts: 391
Don't know if this is any use, I have only used it for 2D work in Photoshop and it tiles quite nicely.
Old 01-09-2008, 04:30 AM
Rep: 10 Posts: 28
Cheers mate that worked a treat
Old 01-09-2008, 08:11 AM
Rep: 206 Posts: 391
I've got these ones as well if you want something more subtle.
Old 01-09-2008, 11:59 AM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
Andrew, tiles nicely, i've saved the map, thanks
Old 01-21-2008, 03:30 PM
Satan Satan is offline
Ingegnere navale
Rep: 10 Posts: 30
You have to use a diffuse map using the texture of carbon fiber after use two layer of reflection
1 fresnel color gray and black
2 an inverse texture of carbon fiber
Good luck.
Old 01-22-2008, 03:08 AM
Rep: 206 Posts: 391
Looks like you also need to add some specular reflection to really get it looking like CF
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 03:55 AM
upholstery designs prototyping pattern maker upholstery man Services & Employment 0 08-09-2007 09:53 PM
Treadmaster Original "S" Pattern for Sale sailrjim Marketplace 0 01-25-2007 10:57 PM
How to reproduce a nonskid pattern jbassion Fiberglass and Composite Boat Building 12 10-08-2006 05:28 AM
Flat pattern problem Hezus Software 8 08-03-2006 12:46 AM
